hi there,
I have some problem when I untar the Angstrom image in the directory mmcblk0p2. I do cd /dev/mmcblk0p2 (the second partition) but appears the message “directory not found”.
someone can help me?
thks
hi there,
thks
/dev/mmcblk0p2 is a device FILE not a directory. Where do you have the partition mounted?
Eric
Insert your SD card and type “df -h” command in terminal to know on which device your card is mounted.
Jyothi
Tenet Technetronics
