Angstrom site problems?
I just tried a fresh install using the instructions on http://www.angstrom-distribution.org/building-angstrom (for MACHINE=beaglebone), no errors reported but got nothing under sources apart from "layers.txt".
Did you go through all the steps? The majority of the recipes, etc,
are not downloaded until the 'update' step.
I have done this before.
Here is the complete console log:
dlambert@development:~$ git clone git://github.com/Angstrom-distribution/setup-scripts.git
Cloning into 'setup-scripts'...
remote: Counting objects: 842, done.
remote: Compressing objects: 100% (383/383), done.
remote: Total 842 (delta 394), reused 827 (delta 383)
Receiving objects: 100% (842/842), 105.91 KiB, done.
Resolving deltas: 100% (394/394), done.
dlambert@development:~$ cd setup-scripts/
dlambert@development:~/setup-scripts$ MACHINE=beaglebone ./oebb.sh config beaglebone
Processing bitbake: Fixed to revision b1dbc24ebcc4e5100c32568c2c41fd982fb4bcce, skipping update
Processing meta-angstrom: Current branch angstrom-v2012.05-yocto1.2 is up to date.
Processing meta-openembedded: Current branch denzil is up to date.
Processing meta-ti: Current branch denzil is up to date.
Processing meta-ettus: Fixed to revision 5a6a642f6707dc42a5210dbbf01d2bdfd869d4b0, skipping update
Processing meta-efikamx: Fixed to revision 2c09a3a780b23448e8a6ca964256ff7f5ccba65d, skipping update
Processing meta-nslu2: Fixed to revision 3d9fc951b05b4df476374b6fc3085ebac7f293ee, skipping update
Processing meta-smartphone: Fixed to revision 2b106be01228f64298d6cb338f93088806594344, skipping update
Processing meta-intel: Fixed to revision f75f9b6f68473eb0efac802409608f8389be0030, skipping update
Processing meta-xilinx: Fixed to revision 5191333565f9913b6175bb19485f7320db82080b, skipping update
Processing meta-openpandora: Fixed to revision 9221a48cd088707e0b03f27704c5825fb754bc0c, skipping update
Processing meta-raspberrypi: Current branch denzil is up to date.
Processing meta-handheld: Fixed to revision 1f05a15aceb4c3a19fa070463b58125b5658b2a9, skipping update
Processing meta-opie: Fixed to revision efa3892b20a4ef80274e56e5633ebd62c16f9731, skipping update
Processing meta-java: Fixed to revision 3386ea6c96096f107f43f282f654e5afa456109e, skipping update
Processing meta-browser: Fixed to revision c47f59df2e723495679c751cbdf6a8c6adec4b6a, skipping update
Processing meta-mono: Fixed to revision 83f8233b0498aadb18bf7605c3ba6c71d9e13a3a, skipping update
Processing meta-kde: Fixed to revision 5b0882d951cfd71886d423c190faaa7c7f932333, skipping update
Processing openembedded-core: Current branch denzil is up to date.
Setup for beaglebone completed
dlambert@development:~/setup-scripts$ MACHINE=beaglebone ./oebb.sh update
dlambert@development:~/setup-scripts$ ls sources/
layers.txt
The place the "sources" end up is stored in an environment variable. If you've run this
before on this machine, the OLD location is where the files will end up.
$ cat ~/.oe/environment-oecore
export SCRIPTS_BASE_VERSION=3
export BBFETCH2=True
export DISTRO="angstrom-2010.x"
export DISTRO_DIRNAME="angstrom_2010_x"
export OE_BUILD_DIR="/local/new-angstrom"
export BUILDDIR="/local/new-angstrom"
export OE_BUILD_TMPDIR="/local/new-angstrom/build/tmp-angstrom_2010_x"
export OE_SOURCE_DIR="/local/new-angstrom/sources"
export OE_BASE="/local/new-angstrom"
export PATH="/local/new-angstrom/sources/openembedded-core/scripts:/local/new-angstrom/sources/bitbake/bin:/opt/amltd/bin:/usr/java/jdk1.6.0_10/bin:/home/gthomas/Android/android-sdk-linux_x86-1.1_r1/tools:/home/gthomas/bin:/usr/lib/qt-3.3/bin:/usr/kerberos/sbin:/usr/kerberos/bin:/usr/lib/ccache:/usr/local/bin:/bin:/usr/bin:/usr/local/sbin:/usr/sbin:/sbin"
export BB_ENV_EXTRAWHITE="MACHINE DISTRO TCLIBC TCMODE GIT_PROXY_COMMAND http_proxy ftp_proxy https_proxy all_proxy ALL_PROXY no_proxy SSH_AGENT_PID SSH_AUTH_SOCK BB_SRCREV_POLICY SDKMACHINE BB_NUMBER_THREADS"
export BBPATH="/local/new-angstrom:/local/new-angstrom/sources/openembedded-core/meta"
If you want a whole new checkout, try getting rid of that script and rerunning the 'configure' step.
Thanks Gary. This is not the first time I have been "tricked" by ~/.xxx files :-[
Dave.
