[ANN] gst-dsp 0.10.1 released
Time for another minor release.
Mostly cleanups this time, but there's a few fixes that should improve
reliability.
Also, there's support support for TIDSPBRIDGE_CACHE_LINE_CHECK, so you
don't have to disable it anymore. And the "new" DMA API;
begin_dma/end_dma ioctls.
Most of these changes have been thoroughly tested in the internal
maemo6 branch, which is now public (and rebased on top of this
release):
https://meego.gitorious.org/maemo-multimedia/gst-dsp/commits/maemo6-patches
There's already some stuff on the 'next' branch that I don't want to merge yet.
Next step is to cleanup the 'maemo6-patches' branch, and hopefully
merge most, if not all the patches :slight_smile:
You can download the tarball from the usual place:
http://code.google.com/p/gst-dsp/downloads/list
Cheers.
Felipe Contreras (20):
base: trivial cleanups
Add gstdsp_vdec_len_fixup() helper
tidsp/*dec: fix all the lengths of decoder output
Use new DMA API
Activate pinned buffers for missing encoders
base: handle possible pinned buffer leaks
ipp: fix direction of intermediary buffer
ipp: fix direction of more buffers
Change dmm_buffer size/len semantics a bit
dmm_buffer: store correct size (aligned)
Trivial cleanups for 'len'
Refactor code into common gstdsp_map_buffer()
util: cleanup gstdsp_map_buffer() a bit
Use b->dir instead lf b->alignment
Remove unused 'alignment' field
util: cleanup a bit
util: cleanup gstdsp_map_buffer() variables
util: improve buffer alignment warning message
bridge: add extra safety to be nice with valgrind
dmm_buffer: set correct buffer attributes
Mark Nauwelaerts (3):
tidsp: mp4venc: fix codec_data leak
tidsp: mp4venc: ensure availability of codec data
venc: indicate in src caps that h264 encoder produces au aligned data
> improve reliability.
Thanks, added to buildroot.
Thanks. I wonder what's the best way to announce these releases so
they get picked to buildroot (it sometimes takes me some time to do
that myself). Is the beagleboard mailing list fine for you?
Cheers.
I only recently started following the beagleboard list, and can't
promise I'll continue doing it forever.
After ELCE we had a discussion about aggregating various embedded Linux
related news and blogs on something like planet.elinux.org, but so far
nothing has come out of it.
