[ANN] gst-dsp 0.10.2 released
This is basically a brown-paper-bag release since the previous one is
totally broken (if you use DSP_API=2, which you should).
Also, a few fixes from the Maemo 6 branch, and some fixes for old
versions of the JPEG encoder (which is the only one that works from
the public release), and a fix for a regression in video call.
You can download the tarball from the usual place:
http://code.google.com/p/gst-dsp/downloads/list
Cheers.
Felipe Contreras (6):
      dmm_buffer: fix for DSP_API=2
      util: fix map_buffer() warning message
      base: fix access to correct dmm_buffer data
      ipp: fix alignment of strings
      jpeg: fixes for old socket-node
      README: add compatibility notes
