I ordered mine from Digikey on Sept 21st and it arrived Sept 23rd. Product is amazingly small and looks beautiful. I also like the plastic packaging. This is really a low cost BeagleBone Module. With this module, Developers can now make their own hardware without the need for fine pitch PCB layout skills.
Any chance the RGB interface will still work over the headers? I realize (and appreciate) that the hdmi is gone but would like to use this for a video source application where we had been using the Beaglebone Black.
Out of the box, plugging the PB into a USB port a single blue LED turns on and nothing shows up on any PC connected to it.
Is there an OS pre-installed or do I have to use an image on microSD card to boot?
Will the USB show up as a serial device or do I have to hard wire the RX and TX pins to a USB TTL-232R-3V3 converter?
Can I use an OTG Micro USB adapter to plug in a USB ethernet device?
In addition to microSD, the SPI0, UART0 and USB0 interfaces are all boot sources. The node-beagle-boot and BeagleBoot projects will eventually work with PocketBeagle and could boot ramdisk images. They will also expose the device as USB flash storage with a microSD card inserted.
Over the usb port, a usb ethernet and usb serial port will show up..
I don't have that configured yet..
I've done (USB WiFi) it by providing 5V into the USB VIN pin on the expansion headers and a micro-type-B to female-type-A cable. I also used the USB on the expansion pins as a USB host or client. For USB1 on the expansion header, you need to set the role with a change in the device tree as best I could get to work.
You use the “USB-tether-gadget”, which, when your USB cable is connected to a Windows host computer, allows you to bridge and share the Ethernet port on the Windows host.
I followed the steps including going to the maker.io on digikey. I have logged into the pocket but not under root that didn’t seem to work. I didn’t have the password. But I did log in under debian. But I’m having trouble getting the pocket to see the internet. no ping. I think the instruction maybe for windows 7. I’m using 10. When I change the properties on the wifi it looks a little different but I did find the sharing. and I set the IPm adress and DNS address.
You use the "USB-tether-gadget", which, when your USB cable is connected
That didn’t work. But I noticed that there is redirection (is that what you call it) for the file resolv.conf. it linkis to /run/connman/resolv.conf there is also a folder in /etc that is called resolv.conf. in the folder there is update.d and update-libc.d.
I looked in the resolv.conf file with my editor and it has the “namespace 8.8.8.8” in the file. I assume it’s supposed to have the quotes
The following is an outline of what to do to connect a PocketBeagle to the internet via the USB cable to a Windows 10 desktop which is connected to the Internet via hardwire Ethernet.
Will there be a wireless version of the PocketBeagle?
It is like the Raspberry Pi Zero. The wireless connectivity was lacking, so now they have the Raspberry Pi Zero W.
torstai 21. syyskuuta 2017 18.35.38 UTC+3 Jason Kridner kirjoitti:
Still doesn’t work. But I noticed my image is 9/21/17. Older than yours. Do you think that could be the problem. I’ll give it a try.
Thanks Graham
Andy
