any suggestion on working behind company firewall?
Hi, BB community,
I am working behind company's firewall, I did manage to get
openEmbedded via git. However, I got the following error in the
angstrom building process using OE:
OE:beagleboard chuqdd@vu32:~/oe$ bitbake console-image
NOTE: Handling BitBake files: \ (6650/6650) [100 %]
NOTE: Parsing finished. 6369 cached, 0 parsed, 281 skipped, 0 masked.
NOTE: Cache is clean, not saving.
NOTE: build 200905211357: started
--2009-05-21 12:46:38-- http://download.savannah.gnu.org/releases/quilt/quilt-0.46.tar.gz
Resolving download.savannah.gnu.org... failed: Name or service not
known.
wget: unable to resolve host address `download.savannah.gnu.org'
NOTE: fetch http://www.angstrom-distribution.org/unstable/sources/quilt-0.46.tar.gz
--2009-05-21 12:46:38-- http://www.angstrom-distribution.org/unstable/sources/quilt-0.46.tar.gz
Resolving www.angstrom-distribution.org... failed: Name or service not
known.
wget: unable to resolve host address `www.angstrom-distribution.org'
NOTE: Task failed: Fetch failed: http://download.savannah.gnu.org/releases/quilt/quilt-0.46.tar.gz
NOTE: package quilt-native-0.46-r2: task do_fetch: failed
ERROR: TaskFailed event exception, aborting
ERROR: Build of /home/chud/oe/openembedded/recipes/quilt/quilt-
native_0.46.bb do_fetch failed
ERROR: Task 32 (/home/chud/oe/openembedded/recipes/quilt/quilt-
native_0.46.bb, do_fetch) failed
NOTE: Tasks Summary: Attempted 19 tasks of which 0 didn't need to be
rerun and 1 failed.
ERROR: '/home/chud/oe/openembedded/recipes/quilt/quilt-native_0.46.bb'
failed
NOTE: build 200905211238: completed
Basically it says host address `www.angstrom-distribution.org' can
not be resolved. It is true in the sense that I got the error of "**
server can't find www.angstrom-distribution.org: NXDOMAIN" if
"nslookup www.angstrom-distribution.org"; but if I just type" nslookup
www.angstrom-distribution.org" in the browser (firefox) address bar,
the browser has no problem finding the right address and download the
"quilt-0.46.tar.gz"
I guess this has to do with my company firewall policy, it is not
"www.angstrom-distribution.org", any external URL can not be resolved
in command line but the web browser can.
Anybody has experience dealing with this situation?
Thank you,
chuqdd
Hi, BB community,
known.
known.
rerun and 1 failed.
failed
"nslookup www.angstrom-distribution.org"; but if I just type "
"quilt-0.46.tar.gz"
I guess this has to do with my company firewall policy, it is not just
Thank you,
chuqdd
Hi Chuqdd,
In order to use most Linux command line tools, you need to set the
http_proxy and ftp_proxy variables in your bash-environment. Search Google
for something like "wget proxy", "Open Embedded proxy" or similar.
Please find a quick starting point below.
Good luck
  Søren
Hi Chuqdd,
From: beagleboard@googlegroups.com [mailto:beagleboard@googlegroups.com]
On Behalf Of chuqdd
Sent: Friday, May 22, 2009 12:43 AM
To: Beagle Board
Subject: [beagleboard] Re: any suggestion on working behind company
firewall?
Hi, BB community,
On ubuntu 8.10 - I did the following to build Angstrom stable branch.
(1) Create/edit .wgetrc in HOME folder with below lines
http_proxy = <proxy.company.com>:<proxy port>
ftp_proxy = <proxy.company.com>:<proxy port>
(2) Create/edit .subversion/servers to add following lines
(To install subversion, sudo apt-get install subversion)
[global]
http-proxy-exceptions = *.company.com
http-proxy-host = <proxy.company.com>
http-proxy-port = <proxy port>
(3) Make GIT proxy-aware (To install git, sudo apt-get install git-core)
- sudo apt-get install corkscrew
- create a shell script say "git-proxy" in ~/bin folder as shown below
#!/bin/sh
exec corkscrew <proxy.company.com> <proxy port> $*
(4) Do export GIT_PROXY_COMMAND=~/bin/git-proxy in the shell were you do bitbake command
Soren and TK,
Thank you for the help.
I tried your suggestions, and found out only doing so in the /etc/
wgetrc will work.
chuqdd
