Playing around with Cloud9 and when I tried to run schmux.js it told me I needed to install "fibers".. I ran the curl and it worked.
When I ran the "npm install fibers" I got a bunch of err's...
What does "failed with 2" mean?
npm@1.0.106 /usr/lib/node_modules/npm
It worked
root@beaglebone:/var/lib/cloud9# npm install fibers
> fibers@0.5.1 install /var/lib/cloud9/node_modules/fibers
> make clean all
make -C src clean
make[1]: Entering directory `/var/lib/cloud9/node_modules/fibers/src'
rm -f fibers.node libcoro.o coroutine.so
rm -f -r *.dSYM
make[1]: Leaving directory `/var/lib/cloud9/node_modules/fibers/src'
rm -f -r man
make -C src coroutine.so
cc -Wall -Wno-deprecated-declarations -I/usr/include -I/usr/include/node -g -O3 -minline-all-stringops -m32 -DCORO_UCONTEXT -fPIC -c -o libcoro.o libcoro/coro.c
cc1: error: unrecognized command line option "-minline-all-stringops"
cc1: error: unrecognized command line option "-m32"
make[1]: *** [libcoro.o] Error 1
make: *** [/var/lib/cloud9/node_modules/fibers/src/coroutine.so] Error 2
npm ERR! error installing fibers@0.5.1 Error: fibers@0.5.1 install: `make clean all`
npm ERR! error installing fibers@0.5.1 `sh "-c" "make clean all"` failed with 2
npm ERR! error installing fibers@0.5.1 at ChildProcess.<anonymous> (/usr/lib/node_modules/npm/lib/utils/exec.js:49:20)
npm ERR! error installing fibers@0.5.1 at ChildProcess.emit (events.js:67:17)
npm ERR! error installing fibers@0.5.1 at ChildProcess.onexit (child_process.js:192:12)
npm ERR! fibers@0.5.1 install: `make clean all`
npm ERR! `sh "-c" "make clean all"` failed with 2
npm ERR!
npm ERR! Failed at the fibers@0.5.1 install script.
npm ERR! This is most likely a problem with the fibers package,
npm ERR! not with npm itself.
npm ERR! Tell the author that this fails on your system:
npm ERR! make clean all
npm ERR! You can get their info via:
npm ERR! npm owner ls fibers
npm ERR! There is likely additional logging output above.
npm ERR!
npm ERR! System Linux 3.1.0+
npm ERR! command "node" "/usr/bin/npm" "install" "fibers"
npm ERR! cwd /var/lib/cloud9
npm ERR! node -v v0.4.12
npm ERR! npm -v 1.0.106
npm ERR! code ELIFECYCLE
npm ERR!
npm ERR! Additional logging details can be found in:
npm ERR! /var/lib/cloud9/npm-debug.log
npm not ok
