I built the kernel 2.6.27 from various sources (2.6.27-omap1 patche,
android, etc.), and I have an issue when I try to capture audio.
Playing audio works just fine (in this case the wav file I am playing
was not recorded on the beagle).
I use these 2 commands:
arecord -D ctl.mixer0 -t wav -c 2 -r 44100 -f S16_LE -v /test.wav -d10
aplay -D ctl.mixer0 -t wav -c 2 -r 44100 -f S16_LE -v /test.wav
Devices entries in the kernel:
Character devices:
14 sound
116 alsa
/dev devices:
crw-r--r-- 1 root root 14, 4 Jan 1 00:00 audio
crw-r--r-- 1 root root 14, 3 Jan 1 00:00 dsp
crw-r--r-- 1 root root 14, 0 Jan 1 00:00 mixer
Mixer configuration file:
# cat /etc/asound.conf
# default dmix configuration
pcm.!default {
type plug
slave.pcm "dmix"
ctl.mixer0 {
type hw
card 0
Any idea what I am missing ?
Thanks!
~Olivier
