Thanks all for the replies.
Pinging works:
ubuntu@arm:~$ ping ports.ubuntu.com
PING ports.ubuntu.com (91.189.88.140) 56(84) bytes of data.
64 bytes from sawo.canonical.com (91.189.88.140): icmp_seq=1 ttl=49 time=19.5 ms
64 bytes from sawo.canonical.com (91.189.88.140): icmp_seq=2 ttl=49 time=17.5 ms
64 bytes from sawo.canonical.com (91.189.88.140): icmp_seq=3 ttl=49 time=18.7 ms
Similar problems with update:
sudo apt-get update
[sudo] password for ubuntu:
Ign http://repos.rcn-ee.net trusty InRelease
Ign http://ports.ubuntu.com trusty InRelease
Ign http://ports.ubuntu.com trusty-updates InRelease
Err http://repos.rcn-ee.net trusty Release.gpg
Something wicked happened resolving ‘repos.rcn-ee.net:http’ (-5 - No address associated with hostname)
Hit http://ports.ubuntu.com trusty Release.gpg
Hit http://ports.ubuntu.com trusty-updates Release.gpg
Hit http://repos.rcn-ee.net trusty Release
Hit http://ports.ubuntu.com trusty/main armhf Packages
Ign http://repos.rcn-ee.net trusty/main armhf Packages/DiffIndex
Hit http://ports.ubuntu.com trusty/universe armhf Packages
Hit http://ports.ubuntu.com trusty/multiverse armhf Packages
Hit http://ports.ubuntu.com trusty/main Translation-en
Hit http://ports.ubuntu.com trusty/multiverse Translation-en
Hit http://ports.ubuntu.com trusty/universe Translation-en
Hit http://ports.ubuntu.com trusty-updates/main armhf Packages
Hit http://ports.ubuntu.com trusty-updates/universe armhf Packages
Hit http://ports.ubuntu.com trusty-updates/multiverse armhf Packages
Hit http://ports.ubuntu.com trusty-updates/main Translation-en
Hit http://ports.ubuntu.com trusty-updates/multiverse Translation-en
Hit http://ports.ubuntu.com trusty-updates/universe Translation-en
Ign http://ports.ubuntu.com trusty/main Translation-en_US
Ign http://ports.ubuntu.com trusty/multiverse Translation-en_US
Ign http://ports.ubuntu.com trusty/universe Translation-en_US
Hit http://repos.rcn-ee.net trusty/main armhf Packages
Ign http://repos.rcn-ee.net trusty/main Translation-en_US
W: Failed to fetch http://repos.rcn-ee.net/ubuntu/dists/trusty/Release.gpg Something wicked happened resolving ‘repos.rcn-ee.net:http’ (-5 - No address associated with hostname)
E: Some index files failed to download. They have been ignored, or old ones used instead.
A clean seems to temporary fix the issue:
ubuntu@arm:~$ sudo apt-get update
Get:1 http://ports.ubuntu.com trusty-updates Release.gpg [933 B]
Get:2 http://ports.ubuntu.com trusty-updates Release [62.0 kB]
Get:3 http://repos.rcn-ee.net trusty Release.gpg [819 B]
Get:4 http://ports.ubuntu.com trusty-updates/main armhf Packages [327 kB]
Get:5 http://ports.ubuntu.com trusty-updates/universe armhf Packages [218 kB]
Get:6 http://ports.ubuntu.com trusty-updates/multiverse armhf Packages [7,721 B]
Fetched 616 kB in 18s (33.8 kB/s)
Reading package lists… Done
But trying to install LXDE brings me back to same issue:
sudo apt-get install lxde && lxde-core && lxde-icon-theme
displays loads of packages…
0 upgraded, 365 newly installed, 0 to remove and 21 not upgraded.
Need to get 125 MB of archives.
After this operation, 428 MB of additional disk space will be used.
Do you want to continue? [Y/n] y
Err http://ports.ubuntu.com/ubuntu-ports/ trusty/main libcap-ng0 armhf 0.7.3-1ubuntu2
Something wicked happened resolving ‘ports.ubuntu.com:http’ (-5 - No address associated with hostname)
Get:1 http://ports.ubuntu.com/ubuntu-ports/ trusty-updates/main libglib2.0-0 armhf 2.40.2-0ubuntu1 [919 kB]
Get:2 http://ports.ubuntu.com/ubuntu-ports/ trusty/main libdbus-glib-1-2 armhf 0.100.2-1 [58.7 kB]
Get:3 http://ports.ubuntu.com/ubuntu-ports/ trusty-updates/main libelf1 armhf 0.158-0ubuntu5.1 [38.1 kB]
Get:4 http://ports.ubuntu.com/ubuntu-ports/ trusty/main libfuse2 armhf 2.9.2-4ubuntu4 [76.8 kB]
Get:5 http://ports.ubuntu.com/ubuntu-ports/ trusty/main libgck-1-0 armhf 3.10.1-1 [65.8 kB]
Get:6 http://ports.ubuntu.com/ubuntu-ports/ trusty/main libgcr-3-common all 3.10.1-1 [8,482 B]
Get:7 http://ports.ubuntu.com/ubuntu-ports/ trusty/main libgcr-base-3-1 armhf 3.10.1-1 [151 kB]
Get:8 http://ports.ubuntu.com/ubuntu-ports/ trusty-updates/main libsystemd-daemon0 armhf 204-5ubuntu20.9 [8,840 B]
Get:9 http://ports.ubuntu.com/ubuntu-ports/ trusty/main systemd-shim armhf 6-2bzr1 [10.2 kB]
My interfaces file:
ubuntu@arm:~$ cat /etc/network/interfaces
This file describes the network interfaces available on your system
and how to activate them. For more information, see interfaces(5).
The loopback network interface
auto lo
iface lo inet loopback
The primary network interface
auto eth0
iface eth0 inet dhcp
Example to keep MAC address between reboots
#hwaddress ether DE:AD:BE:EF:CA:FE
The secondary network interface
#auto eth1
#iface eth1 inet dhcp
WiFi Example
#auto wlan0
#iface wlan0 inet dhcp
wpa-ssid “essid”
wpa-psk “password”
Ethernet/RNDIS gadget (g_ether)
… or on host side, usbnet and random hwaddr
Note on some boards, usb0 is automaticly setup with an init script
iface usb0 inet static
address 192.168.7.2
netmask 255.255.255.0
network 192.168.7.0
gateway 192.168.7.1
Thanks for suggestions but stumped!
Leo
