It seems there is a lot of hard work under way in regards to preparing a 3.14 Kernel for distribution as the standard BBB release.
Could the the armhf 3.14 kernel (http://www.armhf.com/download/) be used as a basis for the BBB 3.14 standard. The reason I ask is that mono installs very easily on the armhf kernel. However, I cannot get it to install on any non armhf kernel. Also floats and date math work correctly as well.
Everything else being equal could the armhf 3.14 kernel be used?
Ahh.. since when does the "kernel" depend on "mono/floats/date" ?
Ahh… since when does the “kernel” depend on “mono/floats/date” ?
Admittedly, the float issue is a mono problem and there is no reason why the BBB standard release should have to pander to it on that basis alone.
However, being able to install mono with a simple apt-get could make the BBB useful to a wider audience. Maybe it is possible to install mono on BBB with a soft float kernel but I sure could not get it to work - I am not especially expert at this sort of thing.
Maybe there are other good reasons to go armhf - maybe there are a lot of good reasons to avoid it. I really do not know. I just thought I would raise the subject to see if it had been considered.
"soft float kernel" umm... "floating point" is not allowed in the
kernel api <period>... (recently there has been added neon
acceleration drivers, yet they still need to talk to the kernel in
"non-float" abi..)
Maybe "fix" mono in debian???
The fix in my opinion is to use something else.
The problem with .NET programmers is that every problem starts looking like a .NET problem. Broaden your horizons . . . Use something that actually makes sense to use with Linux. Nodejs ? Python ? Perl ?
