I’m wondering what ports we should use to connect a microphone breakout board to the pocket beagle. The microphone board has three ports (GND, VCC, & AUD). Thanks
On Fri, 6 Apr 2018 09:54:14 -0700 (PDT),
bcavner26@gmail.com declaimed the following:
I'm wondering what ports we should use to connect a microphone breakout
& AUD). Thanks
To quote from the intro narration of /The Prisoner/:
We want... Information
If the board is commercial, a link to a supplier or spec sheet would be
desirable.
What is "AUD"?
Analog data normalized to Line-Out levels (consumer or professional --
they differ)?
Streaming digital? What sample width, what sample rate, mono/stereo?
PWM?
Is the board rated to operate on 3.3V? If not, you may need to insert
some sort of level-shifter...
