Why does the audio cape use a separate 1.8V LDO to power the codec when there is a 1.8V rail on the expansion connector?
Because there is not a 1.8V rail on the expansion header.
Doesn’t the VADC (P9 Pin32) provide 1.8V? Or is that pin strictly reserved just as a reference voltage and isn’t meant to drive other circuitry?
Max
Yes. And it is for the ADC and not to be used for anything else. Typing stuff to the DDR power bus, like audio capes, not exactly a good idea.
Got it. Thanks
Max
Is it only a reference, or can be used to power circuitry in the
analog front-end?
j.
It is intended as a reference. On the BB, the 1.8V also powered the DDR. On the BBB, it is set to 1.5/1.35V so I had to use another regulator for the 1.8V. That regulator can’t supply anywhere near the current as the BB, so on the BBB that make it even less attractive as a voltage suppy
