Audio cape with Jessie
Hi all,
I have a CircuitCo audio cape, rev. B1 (http://elinux.org/CircuitCo:Audio_Cape_RevB) that works great on a BBB with Wheezy. When I flash the BBB with Jessie (2015-02-15 release), I can’t get it working.
In /boot/uEnv.txt, I have these lines active:
cape_disable=capemgr.disable_partno=BB-BONELT-HDMI
cape_enable=capemgr.enable_partno=BB-BONE-AUDI-02
When the board boots, I can see the right stuff in the kernel command line:
Kernel command line: console=ttyO0,115200n8 capemgr.disable_partno=BB-BONELT-HDMI capemgr.enable_partno=BB-BONE-AUDI-02 root=UUID=625467d4-5b2b-4ade-96f2-43a61ed56731 ro rootfstype=ext4 rootwait fixrtc quiet
Kernel is: Linux 3.14.33-ti-r50 #1 SMP PREEMPT Wed Feb 11 18:16:43 UTC 2015 armv7l
I have BB-BONE-AUDI-02-00A0.dtbo in /lib/firmware, and the pins listed in dmesg match what I would expect from the .dts file.
From dmesg:
[ 2.665131] bone-pinmux-helper P9_25_pinmux.52: Set initial pinmux mode to audio
[ 2.669150] bone-pinmux-helper P9_28_pinmux.55: Set initial pinmux mode to audio
[ 2.670689] bone-pinmux-helper P9_29_pinmux.56: Set initial pinmux mode to audio
[ 2.673912] bone-pinmux-helper P9_31_pinmux.58: Set initial pinmux mode to audio
And in BB-BONE-AUDI-02-00A0.dts:
exclusive-use =
/* the pin header uses /
“P9.31”, /
mcasp0: mcasp0_aclkx /
“P9.29”, /
mcasp0: mcasp0_fsx /
“P9.28”, /
mcasp0: mcasp0_axr2 /
“P9.25”, /
mcasp0: mcasp0_ahclkx */
But when I try playing a WAV file with aplay, no sound comes out, but no errors are reported.
Does it seem like it should be working, or am I missing something obvious?
Brandon
Hi all,
Wheezy. When I flash the BBB with Jessie (2015-02-15 release), I can't get
it working.
fixrtc quiet
armv7l
If you want to use "capemgr" and the above ^^:
sudo apt-get update ; sudo apt-get install linux-image-3.8.13-bone70 ;
sudo reboot
From dmesg:
to audio
to audio
to audio
to audio
    exclusive-use =
        /* the pin header uses */
        "P9.31", /* mcasp0: mcasp0_aclkx */
        "P9.29", /* mcasp0: mcasp0_fsx */
        "P9.28", /* mcasp0: mcasp0_axr2 */
        "P9.25", /* mcasp0: mcasp0_ahclkx */
3.14 doesn't have capemgr, i've ported a bunch of capes:
http://elinux.org/Beagleboard:Capes_3.8_to_3.14
But for some users, they need to just downgrade back to v3.8.x
> Hi all,
with
get
> it working.
obvious?
Thanks for the hint. It seems that the audio cape is not listed among those
ported, but it looks like there are recent changes to
am335x-bone-audio-revb.dts and am335x-bone-audio-revb.dtsi:
https://github.com/beagleboard/linux/blob/3.14/arch/arm/boot/dts/am335x-bone-audio-revb.dts
https://github.com/beagleboard/linux/blob/3.14/arch/arm/boot/dts/am335x-bone-audio-revb.dtsi
Is it possible that I just need 3.14.33-ti-r51 rather than 3.14.33-ti-r50?
Brandon
Yeah, you can also try:
dtb=am335x-boneblack-audio-revb.dtb
in /boot/uEnv.txt
Awesome, thanks. Will try tomorrow and report results!
Brandon
The 3.14.33-ti-r51 kernel and the dtb line that Robert suggested worked!
Before 3.14.33-ti-r51 and dtb=am335x-boneblack-audio-revb.dtb in
/boot/uEnv.txt, dmesg contained:
ALSA device list:
   #0: TI BeagleBone Black
Afterwards, the pinmux mode to audio stuff disappeared and instead, I saw
in dmesg:
tlv320aic3x-codec 2-0018: Failed to get supply 'IOVDD': -517
tlv320aic3x-codec 2-0018: Failed to request supplies: -517
i2c 2-0018: Driver tlv320aic3x-codec requests probe deferral
davinci_evm sound.60: ASoC: CODEC (null) not registered
davinci_evm sound.60: snd_soc_register_card failed (-517)
platform sound.60: Driver davinci_evm requests probe deferral
davinci_evm sound.60: tlv320aic3x-hifi <-> 48038000.mcasp mapping ok
  ALSA device list:
   #0: DA830 EVM
I'm not actually certain that the kernel upgrade was necessary, but it
worked, so I'll stick with it.
Now when I run aplay, sound comes out. I hear music!
Thanks, Robert!
Brandon
