Audio recording on Angstrom
I've got audio playback running well on the Beagle under Angstrom
linux, but I can't seem to get recording to work.
Issuing the command:
arecord -t wav -c 2 -r 44100 -f S16_LE -v test.wav
Results in the following error:
ALSA lib pcm_dmix.c:947:(snd_pcm_dmix_open) The dmix plugin supports
only playback stream
arecord: main:583: audio open error: Invalid argument
Is audio input not implemented on Angstrom, or is there some other
issue.
Tim
Check /etc/asound.conf to see how dmix is configured.
regards,
Koen
Hi Koen,
I checked asound.conf and realized it wasn't routing to the correct
ctl.mixer0 device. I've worked around this by specifying the device:
arecord -D ctl.mixer0 -t wav -c 2 -r 44100 -f S16_LE -v test.wav
It's now working fine - thanks for your help!
