Bare-Metal Programming On Beagle Bone Black Board
Hello:
Can any one help in learning and practicing Bare-Metal Programming on Beagle Bone Black Board.?
To Start Working With Bare-Metal Programming, what are all the things Should I know.?
  1. How to run programs at boot level.?
  2. Who will start/run the our application in u-boot environment.?
Please suggest any material/books or links for Baremetal Programming.
Thanks and Regards,
Siva Prakash Reddy.
Hi!
There’re several flavors of bare-metal programming on BBB. You can either run the full system bare metal (like on RPi). Or you can run the ARM CPU under Linux while bare-metal firmware is running on one or both PRUSS.
You should specify which kind of bare-metal you want to get info on. The later is pretty simple, ie. you can find examples here.
Regards
