I am running a custom image of Debian Stretch on BBB, downgraded to 4.4.54-ti-r93. On this image, /sys/devices/platform/bone_capemgr/baseboard/serial-number exists. However after I perform an upgrade to 4.4.113-ti-r146 using sudo /opt/scripts/tools/update_kernel.sh --ti-channel --lts-4_4, /sys/devices/platform/bone_capemgr/baseboard/ disappears.
I seek help to clarify if this is a known issue. Thanks!
–Luther
When U-Boot Overlays are active that directory is removed..
I see. I need the serial number of the BBB. Previously I extracted it from /sys/devices/platform/bone_capemgr/baseboard/serial-number. Where can I get the equivalent now?
–Luther
I would also like to know when the U-boot overlays changed from being inactive to being active. Is it specifically during the reboot into the new kernel?
–Luther
–Luther
sudo hexdump -e '8/1 "%c"' /sys/bus/i2c/devices/0-0050/eeprom -n 28 |
cut -b 5-28
well between r93 -> r146..
https://github.com/RobertCNelson/ti-linux-kernel-dev/commits/ti-linux-4.4.y
r93: Mar 16, 2017
r146: Feb 2, 2018
So i'd say mid summer of 2017..
When available, the contents of /sys/devices/platform/bone_capemgr/baseboard/serial-number
and /sys/bus/i2c/devices/0-0050/eeprom
differ. Are they expected to be the same or are they 2 different type of serial numbers altogether? And are both unique? Thanks!
–Luther
For clarity, the difference is as follows. Question: Is one more correct than the other?
cat /sys/devices/platform/bone_capemgr/baseboard/serial-number 4816BBBK2650 # sudo hexdump -e ‘8/1 “%c”’ /sys/bus/i2c/devices/0-0050/eeprom -n 28 | cut -b 5-28 A335BNLTEIA04816BBBK2650
–Luther
A335BNLT -> "BeagleBone Black Family"
EIA0 -> "Element14 BeagleBone Black Industrial"
4816BBBK2650 -> "Serial"
If all you want is the serial, adjust the "5" in the "cut -b 5-28" option
Is there a way to get the serial number without using sudo?
–Luther
