Aadeesh
February 10, 2011, 10:21am
1
I am following http://elinux.org/BeagleBoardUbuntu#DSP to configure
DSP on BeagleXM.
When i execute ./build_kernel.sh, i get an error
aadeesh@ubuntu:~$ ./build_kernel.sh
bash: ./build_kernel.sh: Permission denied
I installed the "Requirements" in
http://bazaar.launchpad.net/~beagleboard-kernel/+junk/2.6-stable/view/head:/readme.txt ,
But still the same error appears.
Also i could not find the system.sh file to do the modifications.
I am using Ubuntu 10.10 as my Host and ubuntu-10.10-r4-minimal-armel
on beagle.
Please help.
Aadeesh
It sounds like you need to mark the file as executable before running it:
chmod 0755 build_kernel.sh
./build_kernel.sh
Bye for now,
Make sure you are actually in the 2.6-stable directory.
I've tried to make the script as idoit proof but let me know if you
run into anything else..
Aadeesh
February 10, 2011, 4:56pm
4
Sorry, i did not understood "2.6-stable directory" ?
Your idiot proof scripts certainly helps a beginner like me.
Aadeesh
Then where did you get the "./build_kernel.sh" script?
You just can't download the script by itself, you need the bzr repo,
as the script requires other files for data/control..
bzr branch lp:~beagleboard-kernel/+junk/2.6-stable
(for bzr haters, i'm planning a conversion to git on github, which
i've done for the devel tree's)
then: cd 2.6-stable/
then "./build_kernel.sh" will work..
Looking at your original email, you were asking about DSP, well the
10.10-r4 already has the correct kernel.. (main reason i updated the
image on feb 5th).
So you just need to run the "./create_dsp_package.sh" from my
2.6-stable to get the dsp libs..
Aadeesh
February 12, 2011, 6:00am
6
ERROR:
aadeesh@ubuntu:~/2.6-stable$ ./build_kernel.sh
+ Detected build host [debian-]
system.sh: line 32: syntax error: unexpected end of file
Also,
aadeesh@ubuntu:~/2.6-stable$ ./create_dsp_package.sh
system.sh: line 22: syntax error near unexpected token `fi'
Aadeesh
Looks like you screwed up the "system.sh" when you copied it from
"system.sh.example"
post it to pastebin.com and i'll comment on it..
Aadeesh
February 12, 2011, 2:07pm
8
I just copied as
cp system.sh.sample system.sh
Pastebin:
http://pastebin.com/D52p4jLB
Also system.sh is as follows
That's what i figured.. I added some more checks to warn users when
they forgot to modified the "#CC=arm-linux-gnueabi-"
The script doesn't care which of the many cross compilers you use...
It just needs to know where to find it..
So modify the CC variable accordingly..
Otherwise, create_dsp_package.sh no longer needs the CC variable so i
removed that check upstream..
http://bazaar.launchpad.net/~beagleboard-kernel/+junk/2.6-stable/revision/167
(it use to compile stuff, now days it just packages the codec's..)
Aadeesh
February 12, 2011, 3:44pm
10
Thanks. Its working now.
Sorry for my silly questions.
You are like my Mentor.
Thank You.
Aadeesh
Hello Robert,
I have system.sh like the following
#!/bin/sh
#copy as “system.sh” and tweak for your system
ARCH=$(uname -m)
#ARM Native gcc compiler (running gcc on arm target)
if [ “x${ARCH}” = “xarmv7l” ] ; then
#Native arm gcc compiler
CC=
fi
###REQUIRED:
#ARM GCC CROSS Compiler:
if CC is not set, a known working linaro based gcc compiler will be downloaded and utilized.
CC=/home/CodeSourcery/Sourcery_CodeBench_Lite_for_ARM_GNU_Linux/bin/arm-none-linux-gnueabi-gcc-
###OPTIONAL:
###OPTIONAL: LINUX_GIT: specify location of locally cloned git tree.
Uhh.. Please don't translate the error message..
Run "./build_kernel.sh" and paste the FULL terminal output of the run
to pastebin.com
ohh sorry, here is the output
http://pastebin.com/raw.php?i=q50MPuC5
Mustafa
10 Aralık 2013 Salı 18:16:00 UTC+2 tarihinde RobertCNelson yazdı:
Remove the extra "if" you un-commented out in the file..
To see which if, just use meld: "meld system.sh.sample system.sh"
