I'm not an electronics guy so I'm hoping you guys can tell me if it
would be possible to replace the switching voltage regulator in either
the BeagleJuice or the Beaglebone Battery Cape with a linear
regulator? My application would benefit from as little EMI as
possible.
Not sure about the juice. On the cape, replacing it will not be that easy. You would be better off wiring up your own cape using one of the proto capes and the linear regulator of choice. You can get your own battery holders. But you need to use lithium batteries as a linear regulator cannot work below 5.3V to 5.7V and still give you 5V out, depending on which regulator you use. That is what theswitcher is for.
Then there are the three switchers on the BeagleBone itself.
possible.
- Grant
Hi Gerald, could you tell me more about the 3 switchers on the
BeagleBone? What are they used for?
Should the BeagleBone transmit a small amount of EMI relative to most computers?
They are used to generate the 1.8V for the processor, the ARM voltage, and the Internal voltages required to make the processor run. They are part of the TPS65217B Power Management IC. The board satisfies the FCC requirement as it relates to emissions.
I would suggest looking at the current rating of the linear regulator you plan to use. The beagleboard takes max of 510mA. A switching regulator is always a better option when you need currents above 500mA. (doesn’t heat up as well)
