BB 4C from USB with u-boot in SDRAM
Hi BB group !
I need some help.
I already test some procedures without success.
I have a BeagleBoard C4 ( classic, not XM ).
I lost the boot due an defective SD card.
Scenario:
1- I have no access to SD card.
2- My NAND is corrupted.
I am trying boot recover thru USB or UART.
I have cross-compiled several x-loader and u-boot, including denx.
My recent try was thru USB using the procedure described here.
http://elinux.org/BeagleBoard#USB_boot
I am not able to find how to do some steps described inside
omap3_usbload.c source code.
I believe my u-boot must be load from SDRAM, ( not NAND or SD ).
I will apreciate any help and directions.
thx in advanced,
julio menezes
you better buy a new sd card and burn it with a fresh linux install, have a serial output and stop the normal boot process, from there erase your NAND and flash it if you want
