bb-bonescript-installer-beta upgrade fails:
make: Entering directory
'/usr/local/lib/node_modules/bonescript/node_modules/ffi/node_modules/ref/build'
CXX(target) Release/obj.target/binding/src/binding.o
SOLINK_MODULE(target) Release/obj.target/binding.node
COPY Release/binding.node
make: Leaving directory
> serialport@2.0.6 install
/usr/local/lib/node_modules/bonescript/node_modules/serialport
> node-pre-gyp install --fallback-to-build
'/usr/local/lib/node_modules/bonescript/node_modules/serialport/build'
CXX(target) Release/obj.target/serialport/src/serialport.o
Killed
dpkg: error processing package bb-bonescript-installer-beta (--configure):
subprocess installed post-installation script returned error exit status
137
Setting up doc-beaglebone-getting-started (1.20151204-2~bpo80+20160421+1)
Errors were encountered while processing:
E: Sub-process /usr/bin/dpkg returned an error code (1)
kernel: 4.1.18-ti-r56
Beagleboard.org Debian Image 2016-04-03
Its been pretty solid up to now, all the bonescript examples (
analogWrite() analogRead(), digitalWrite(), digitalRead() attachInterrupt()
)seem to work without extraneous error or warning messages.
I've been doing apt-get update, apt-get upgrade pretty regularly hoping
to keep current.
Has a required kernel upgrade come it that doesn't install with apt-get
upgrade?
Nope...
I've been using this system the way I figure a newbie who only wanted
bonescript, python, and node-red might do.
I can see how pushing kernel upgrades could rather quickly get you into
space issues if confined to the 4GB eMMC, but if its a real dependency not
doing so would seem to be a problem.
Odd, was this the iot or lxqt or console image?
if you do : dpkg --list | pastebinit
we can compare against:
https://paste.debian.net/440395/
From a fresh 2016-04-03 iot image i'm seeing:
debian@beaglebone:~$ cat /etc/dogtag
BeagleBoard.org Debian Image 2016-04-03
debian@beaglebone:~$ uname -r
4.1.18-ti-r56
debian@beaglebone:~$ sudo apt-get update ; sudo apt-get upgrade
Reading state information... Done
Calculating upgrade... Done
The following packages will be upgraded:
bb-bonescript-installer-beta bb-wl18xx-firmware connman
doc-beaglebone-getting-started libmraa0 linux-libc-dev openssh-client
openssh-server openssh-sftp-server tiomapconf upm
11 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 15.6 MB of archives.
After this operation, 63.5 kB of additional disk space will be used.
Do you want to continue? [Y/n] y
0% [Working]
0% [Waiting for headers] [Waiting for headers]
Get:1 Index of /debian jessie/main libmraa0 armhf
0.9.5-git20160420-0rcnee1~bpo80+20160420+1 [408 kB]
Get:2 http://security.debian.org/ jessie/updates/main openssh-sftp-server
armhf 1:6.7p1-5+deb8u2 [33.2 kB]
Get:3 Index of /debian jessie-updates/main
linux-libc-dev armhf 3.16.7-ckt25-2 [1,004 kB]
Get:4 http://security.debian.org/ jessie/updates/main openssh-server armhf
1:6.7p1-5+deb8u2 [324 kB]
Get:5 Index of /debian jessie/main upm armhf
0.5.1-git20160410-0rcnee1~bpo80+20160410+1 [12.3 MB]
Get:6 http://security.debian.org/ jessie/updates/main openssh-client armhf
1:6.7p1-5+deb8u2 [643 kB]
Get:7 Index of /debian jessie/main
bb-bonescript-installer-beta all 0.5.0~beta4-1rcnee2~bpo80+20160421+1
[4,062 B]
Get:8 Index of /debian jessie/main
doc-beaglebone-getting-started all 1.20151204-2~bpo80+20160421+1 [17.2 kB]
Get:9 Index of /debian jessie/main connman armhf
1.32-git20160418-0rcnee1~bpo80+20160418+1 [307 kB]
Get:10 Index of /debian jessie/main bb-wl18xx-firmware all
1.20160413-0rcnee1~bpo80+20160413+1 [48.1 kB]
Get:11 Index of /debian jessie/main tiomapconf armhf
1.72.0-git20160414-1~bpo80+20160414+1 [535 kB]
Fetched 15.6 MB in 29s (529 kB/s)
Preconfiguring packages ...
(Reading database ... 52946 files and directories currently installed.)
Preparing to unpack
.../libmraa0_0.9.5-git20160420-0rcnee1~bpo80+20160420+1_armhf.deb ...
Unpacking libmraa0:armhf (0.9.5-git20160420-0rcnee1~bpo80+20160420+1) over
(0.9.5-git20160302-0rcnee1~bpo80+20160302+1) ...
Preparing to unpack
.../upm_0.5.1-git20160410-0rcnee1~bpo80+20160410+1_armhf.deb ...
Unpacking upm:armhf (0.5.1-git20160410-0rcnee1~bpo80+20160410+1) over
(0.5.1-git20160302-0rcnee6~bpo80+20160302+1) ...
Preparing to unpack
.../bb-bonescript-installer-beta_0.5.0~beta4-1rcnee2~bpo80+20160421+1_all.deb
Unpacking bb-bonescript-installer-beta
(0.5.0~beta4-1rcnee2~bpo80+20160421+1) over
(0.5.0~beta3-0rcnee1~bpo80+20160226+1) ...
Preparing to unpack
.../doc-beaglebone-getting-started_1.20151204-2~bpo80+20160421+1_all.deb ...
Unpacking doc-beaglebone-getting-started (1.20151204-2~bpo80+20160421+1)
over (1.20151204-1~bpo80+20151207+1) ...
Preparing to unpack .../openssh-sftp-server_1%3a6.7p1-5+deb8u2_armhf.deb ...
Unpacking openssh-sftp-server (1:6.7p1-5+deb8u2) over (1:6.7p1-5+deb8u1) ...
Preparing to unpack .../openssh-server_1%3a6.7p1-5+deb8u2_armhf.deb ...
Unpacking openssh-server (1:6.7p1-5+deb8u2) over (1:6.7p1-5+deb8u1) ...
Preparing to unpack .../openssh-client_1%3a6.7p1-5+deb8u2_armhf.deb ...
Unpacking openssh-client (1:6.7p1-5+deb8u2) over (1:6.7p1-5+deb8u1) ...
Preparing to unpack
.../connman_1.32-git20160418-0rcnee1~bpo80+20160418+1_armhf.deb ...
Unpacking connman (1.32-git20160418-0rcnee1~bpo80+20160418+1) over
(1.31-git20160309-0rcnee1~bpo80+20160309+1) ...
Preparing to unpack .../linux-libc-dev_3.16.7-ckt25-2_armhf.deb ...
Unpacking linux-libc-dev:armhf (3.16.7-ckt25-2) over (3.16.7-ckt25-1) ...
Preparing to unpack
.../bb-wl18xx-firmware_1.20160413-0rcnee1~bpo80+20160413+1_all.deb ...
Unpacking bb-wl18xx-firmware (1.20160413-0rcnee1~bpo80+20160413+1) over
(1.20160310-0rcnee2~bpo80+20160310+1) ...
Preparing to unpack
.../tiomapconf_1.72.0-git20160414-1~bpo80+20160414+1_armhf.deb ...
Unpacking tiomapconf (1.72.0-git20160414-1~bpo80+20160414+1) over
(1.72.0-git20150828-1~bpo80+20151023+1) ...
Processing triggers for man-db (2.7.0.2-5) ...
Processing triggers for systemd (215-17+deb8u4rcnee1~bpo80+20160313+1) ...
Processing triggers for dbus (1.8.20-0+deb8u1) ...
Setting up libmraa0:armhf (0.9.5-git20160420-0rcnee1~bpo80+20160420+1) ...
Setting up upm:armhf (0.5.1-git20160410-0rcnee1~bpo80+20160410+1) ...
Setting up bb-bonescript-installer-beta
(0.5.0~beta4-1rcnee2~bpo80+20160421+1) ...
bb-bonescript-installer:npm: [2.15.0]
bb-bonescript-installer:node: [v0.12.13]
bb-bonescript-installer:Installing: bonescript-0.5.0-beta4 (for bonescript)
[0m systemd@0.2.6: wanted: {"node":">=0.6.11 <0.11.0"} (current:
{"node":"0.12.13","npm":"2.15.0"})
spi@0.2.0 install /usr/local/lib/node_modules/bonescript/node_modules/spi
node-gyp rebuild
[0Gmake: Entering directory
'/usr/local/lib/node_modules/bonescript/node_modules/spi/build'
[0G CXX(target) Release/obj.target/_spi/src/spi_binding.o
[0G../src/spi_binding.cc: In member function ‘void
Spi::full_duplex_transfer(v8::Isolate*, const
v8::FunctionCallbackInfo<v8::Value>&, char*, char*, size_t, uint32_t,
uint16_t, uint8_t)’:
../src/spi_binding.cc:199:3: warning: missing initializer for member
‘spi_ioc_transfer::cs_change’ [-Wmissing-field-initializers]
‘spi_ioc_transfer::tx_nbits’ [-Wmissing-field-initializers]
‘spi_ioc_transfer::rx_nbits’ [-Wmissing-field-initializers]
‘spi_ioc_transfer::pad’ [-Wmissing-field-initializers]
[0G SOLINK_MODULE(target) Release/obj.target/_spi.node
COPY Release/_spi.node
i2c@0.2.1 install /usr/local/lib/node_modules/bonescript/node_modules/i2c
node-gyp rebuild
'/usr/local/lib/node_modules/bonescript/node_modules/i2c/build'
CXX(target) Release/obj.target/i2c/src/i2c.o
[0G SOLINK_MODULE(target) Release/obj.target/i2c.node
[0G COPY Release/i2c.node
epoll@0.1.17 install
/usr/local/lib/node_modules/bonescript/node_modules/epoll
node-gyp rebuild
'/usr/local/lib/node_modules/bonescript/node_modules/epoll/build'
CXX(target) Release/obj.target/epoll/src/epoll.o
[0G SOLINK_MODULE(target) Release/obj.target/epoll.node
COPY Release/epoll.node
ref@1.3.2 install
node-gyp rebuild
ffi@2.0.0 install /usr/local/lib/node_modules/bonescript/node_modules/ffi
node-gyp rebuild
'/usr/local/lib/node_modules/bonescript/node_modules/ffi/build'
CC(target) Release/obj.target/ffi/deps/libffi/src/prep_cif.o
CC(target) Release/obj.target/ffi/deps/libffi/src/types.o
CC(target) Release/obj.target/ffi/deps/libffi/src/raw_api.o
CC(target) Release/obj.target/ffi/deps/libffi/src/java_raw_api.o
CC(target) Release/obj.target/ffi/deps/libffi/src/closures.o
CC(target) Release/obj.target/ffi/deps/libffi/src/arm/ffi.o
../deps/libffi/src/arm/ffi.c: In function ‘ffi_prep_args’:
../deps/libffi/src/arm/ffi.c:72:10: warning: comparison between signed and
unsigned integer expressions [-Wsign-compare]
&& vi < ecif->cif->vfp_nargs && vfp_type_p (*p_arg))
../deps/libffi/src/arm/ffi.c: In function ‘ffi_prep_incoming_args_SYSV’:
../deps/libffi/src/arm/ffi.c:335:10: warning: comparison between signed and
&& vi < cif->vfp_nargs && vfp_type_p (*p_arg))
../deps/libffi/src/arm/ffi.c: In function ‘layout_vfp_args’:
../deps/libffi/src/arm/ffi.c:750:17: warning: comparison between signed and
for (i = 0; i < cif->nargs; i++)
CC(target) Release/obj.target/ffi/deps/libffi/src/arm/sysv.o
AR(target) Release/obj.target/deps/libffi/libffi.a
COPY Release/libffi.a
CXX(target) Release/obj.target/ffi_bindings/src/ffi.o
CXX(target) Release/obj.target/ffi_bindings/src/callback_info.o
CXX(target)
Release/obj.target/ffi_bindings/src/threaded_callback_invokation.o
SOLINK_MODULE(target) Release/obj.target/ffi_bindings.node
COPY Release/ffi_bindings.node
CXX(target) Release/obj.target/serialport/src/serialport_unix.o
CXX(target) Release/obj.target/serialport/src/serialport_poller.o
SOLINK_MODULE(target) Release/obj.target/serialport.node
COPY Release/serialport.node
COPY
/usr/local/lib/node_modules/bonescript/node_modules/serialport/build/Release/node-v14-linux-arm/serialport.node
TOUCH Release/obj.target/action_after_build.stamp
bonescript@0.5.0-beta4 /usr/local/lib/node_modules/bonescript
├── systemd@0.2.6
├── spi@0.2.0 (bindings@1.2.1)
├── winston@2.1.1 (cycle@1.0.3, stack-trace@0.0.9, eyes@0.1.8,
isstream@0.1.2, pkginfo@0.3.1, async@1.0.0, colors@1.0.3)
├── express@4.13.4 (escape-html@1.0.3, utils-merge@1.0.0,
cookie-signature@1.0.6, methods@1.1.2, range-parser@1.0.3, fresh@0.3.0,
vary@1.0.1, parseurl@1.3.1, array-flatten@1.1.1, etag@1.7.0,
content-type@1.0.1, merge-descriptors@1.0.1, path-to-regexp@0.1.7,
cookie@0.1.5, content-disposition@0.5.1, serve-static@1.10.2, depd@1.1.0,
on-finished@2.3.0, finalhandler@0.4.1, qs@4.0.0, debug@2.2.0,
proxy-addr@1.0.10, send@0.13.1, type-is@1.6.12, accepts@1.2.13)
├── i2c@0.2.1 (bindings@1.2.1, repl@0.1.3, underscore@1.8.2,
coffee-script@1.9.1)
├── socket.io@1.4.5 (has-binary@0.1.7, debug@2.2.0, socket.io-parser@2.2.6,
engine.io@1.6.8, socket.io-adapter@0.4.0, socket.io-client@1.4.5)
├── epoll@0.1.17 (bindings@1.2.1, nan@2.2.1)
├── ffi@2.0.0 (bindings@1.2.1, ref-struct@1.0.2, debug@2.2.0, nan@2.2.1,
ref@1.3.2)
└── serialport@2.0.6 (bindings@1.2.1, sf@0.1.7, async@0.9.0, debug@2.2.0,
nan@2.0.9, optimist@0.6.1)
[2Kbb-bonescript-installer:Installed
Setting up openssh-client (1:6.7p1-5+deb8u2) ...
Setting up openssh-sftp-server (1:6.7p1-5+deb8u2) ...
Setting up openssh-server (1:6.7p1-5+deb8u2) ...
Setting up connman (1.32-git20160418-0rcnee1~bpo80+20160418+1) ...
Setting up linux-libc-dev:armhf (3.16.7-ckt25-2) ...
Setting up bb-wl18xx-firmware (1.20160413-0rcnee1~bpo80+20160413+1) ...
Setting up tiomapconf (1.72.0-git20160414-1~bpo80+20160414+1) ...
Processing triggers for libc-bin (2.19-18+deb8u4) ...
debian@beaglebone:~$ node js --version
v0.12.13
debian@beaglebone:~$ /usr/bin/npm --version
2.15.0
