BB ethernet not functioning when running CONFIG_PREEMPT=y kernel
My BeagleBone runs fine with a kernel I compiled, so long at that kernel does not use CONFIG_PREEMPT=y.
I CONFIG_PREEMPT=y is in play, then it still boots off of SD, I get a serial console, and everything except ethernet seems to work.
I cannot ping out, nor in from another machine.
This is true with both 3.1 and 3.2 kernels.
I need the low latency of the CONFIG_PREEMPT for factory automation.
Suggestions?
