I’m a bit confused about the phy ethernet “issue” on beaglebone boards, i want to try those to implement in a current solution where a reliable ethernet is a must.
I read that there is a issue with the ethernet transceiver that cause the board to sometimes don’t have ethernet working.
Seems to be a revision C3 that implements a reset gpio to solve this but i don’t find if the software part to toggle that pin has been implemented in OS.
Sorry if this has been discussed before but i’m unable to find the current status of this.
My boards will arrive this week… but i don’t know if i have ordered the wrong one now that i read this again i forgot the 3 from C3 so i thinked that REV C was ok…
