BB Green and default IP address
I just got a BB green and unfortunately I’m really new to Linux. If I change the Board’s ip adapter to use dhcp will I lose connectivity to it using the usb cable which uses 192.168.7.2?
You can still use the USB on that address if you did not change it manually.
