I have BB Rev C2 board. I downloaded pre-built images for validation
from http://code.google.com/p/beagleboard/wiki/BeagleboardRevCValidation
I followed the instructions given in the above link.
I tried to validate Audio-In and Audio-Out in BB but I did not hear
audio from Audio-Out line of BB but it is only noise sound.
Of course I also tried the recorded file play in PC but nothing
audible it is only noise.
I have connected the UART cable to PC, SDcard to BB, Audio-In cable
from PC and Audio-Out to self powered speakers.
Then I connected USB cable from OTG port of BB to Host port of PC
while pressing USER button and I followed the instructions given in
the above link.
from Google Code Archive - Long-term storage for Google Code Project Hosting.
Can you run the mplayer DVI test, it should play audio as well. This
should confirm your audio out support.
the above link.
> Hi,
> from
Yes it is ramdisk.gz, this has all the utilities to test the beagleboard.
Can you please suggest me whether I can use these sources for
startup??
If you want to validate the board and setup and want a simple rootfs
to work on, then go for the ramdisk image (it's again based on
Angstrom / OE but with limited features for reduced size). If you are
looking for more UI, DSP, SGX, etc then OE / Angstrom build has
support for these components and has been tried on Beagle.
May I know why is not able to test Audio-In and Audio-Out test?
I think this is problem with your line in setup or the way you are
recording the audio. Please double check this one.
I double checked it but not figure out the problem.
What is special setup I need to do?
If I play any song in PC I an hear that from head phones connected. I
am connecting Line-In cable one side to PC's slot(head phone symbol
will be there) where I connect Head Phone and other side to BB's Audio-
In slot ( which is at corner ).
I am giving below command after mounting SD card
arecord -t wav -c 2 -r 44100 -f S16_LE -v k
Then after some time I am pressing Ctrl+C.
Is there anything wrong?
My basic idea is just want create small application to play a wav file
or
small amount of predefined data from buffer on BB with kernel from
code.google.
Is it possible? it may be but as I am new to this world I need group
members help to do so.
Till now I could able run "hello world " program.
Could you please help me
1. what are the options I have to select in kernel with " make
menuconfig "
2. Is there any driver available in kernel
3. what is driver and where it is in kernel
4. Is there any guidelines/ docs available for audio codec to use
5. what are the things to be done in application and kernel
