unfortunately, this did not work for me. USB and ethernet continue to disconnect few minutes after boot.
Davide Rondini
Davide Rondini
This command is only to re-enable USB and ethernet after boot. You will still continue to see the disconnect after boot. Are you seeing the USB and ethernet re-enabling once you issue this command after the OS boots?
No effect. If I issue the command after the disconnect, nothing happens, USB and Ethernet remain dead.
Davide Rondini
