Has anybody else experienced intermittent pvr drm crashes like the one below? Happens relatively seldom, under perfectly good thermal conditions (35C), while running the kmscube test, in the non-atomic (legacy) swap-buffer path, in a surface-less setup, ie. using gbm_bo EGL images.
Thank you for checking, @RobertCNelson Sometime it’s not a crash but a lockup, like one below. Again, such lockups happen seldom – maybe half of the time when the CheckForStalledCCB issue generally occurs. So, to sum it up:
it always starts with a CheckForStalledCCB
sometimes it manifests as a crash with a subsequent recovery
