What is the recommended mating header for the BBAI-64 mikroBUS implementation? I can’t seem to locate any tall enough to bypass the ethernet and usb connectors.
Thanks. Actually I was hoping to design 4" x 1" expansion board with a female header mounted to the bottom of it that would rise above the usb and ethernet connector. But standoffs and a cable makes it easier.
BTW, I’m using the this enclosure for my BBAI-64 and I am customizing it for my prototype.
Cool, first i’ve seen of that case, i’ll check it out…
With the Shuttle ribbon cable, you can really mount it anywhere on that box…
