For the solution currently being developed, a standalone display module has to be integrated with the BeagleBone-AI board (preferably supporting touch input). This post is to understand if anyone has used the NHD-7.0CTP-CAPE-N display module available at:
https://www.digikey.com/en/product-highlight/n/newhaven-display/7-beaglebone-capes
In the specifications of this display, it is mentioned that the display module is compatible with BBB, and as the BB-AI is backward compatible with BBB(pin layout and sw), can this module be efficiently used/integrated with BB-AI?
If yes, could you please help us with the correct way/method to do so.
If not, could you please suggest a suitable/compatible display for the same.
Many thanks!
Best,
Ak
