I was fiddling around the beagle-flasher script to change the vfat partition to ext4 instead, but I think I bricked the mmcblk0boot partitions because the BBAI64 does not want to boot from the eMMC nor the SD card anymore. I know the SD card still works because I tested it with other BBAI64.
Is there a way to recover from this situation?
Sadly, today the bootrom requires vfat…
- Plug in microSD
- Hold RESET & BOOT
- Plug in Power
- Lift up finger on RESET
- Wait for LED
- Lift up finger on BOOT
- Device boots from microSD…
I tried with another image and this works thanks.
I’m not trying to have the bootrom on ext4 but the mmcblk0p1 as ext4. I have some problems where the whole system goes into read-only when not properly shutting down the unit and so far with ext4 partition on mmcblk1p1 (sd card), I do not have this issue. I don’t know if the solution is related to the problem but I’m trying a lot of stuff right now.
Thank you!
Follow up, changing the partition to ext4 did not solve the read-only mount problem.
