BBAI64 eMMC Dead out of Box?
Hello All,
I post this very hesitantly as a neophyte to BeagleBone AI-64, but after several days of working at this, I’m coming to the suspicion that the onboard eMMC is not working properly. I’ve linked a similar thread below. I will post my detailed troubleshooting - please let me know if I am missing something obvious or if you as a community agree the board is not behaving properly.
Detailed Information
BeagleBone AI-64 purchased new from Vilros.com on 9/26/26. Everything about the board and shipment appears genuine and new. Using 5V 3A (15W) DC barrel jack power adapter.
BBAI64 would not boot to linux desktop out of the box while following all Quick Start documentation. USB tether not functional. MiniDP only shows black screen with blinking white cursor. Using quality MiniDP to DP cable, no HDMI conversion. No UBoot info displays, no Linux Kernel startup displays. LED pattern did not match any descriptions of expected behavior. LED2 (SD) is constant ON.
BBAI64 would not flash via SD card. Prepared SD card with both BalenaEtcher and Beagle Board Imaging Utility with the Debian 13 (Trixie) v6.18.x-k3 XFCE 2026-09-20 image. Held BOOT button and applied power. Continued to apply power until LEDs appeared. Pong/Chase LED pattern never appeared.
When SD card with aforementioned image is inserted, the BBAI64 boots and mounts as a removable drive in Windows 11. SSH is permitted and indicates 2022-01-14 image.
Running the command:
sudo apt update && sudo apt upgrade -y
sudo beagle-flasher
Returns the failure:
Version: [1.20220112.0: add cleanup grow_partition.service and beagle-flasher-init-shutdown.service...]
cat /etc/default/beagle-flasher:
source=/dev/mmcblk1
destination=/dev/mmcblk0
rfs_partition=dual
rfs_boot_startmb=1
rfs_boot_size_mb=128
bootloader=/opt/u-boot/bb-u-boot-beagleboneai64/install-emmc.sh
flash_back=bbai64-emmc-to-microsd
extlinux=/opt/u-boot/bb-u-boot-beagleboneai64/emmc-extlinux.conf
INFO: [lsblk -i]
NAME        MAJ:MIN RM  SIZE RO TYPE MOUNTPOINT
mmcblk1     179:0    0 29.7G  0 disk
|-mmcblk1p1 179:1    0  128M  0 part /boot/firmware
`-mmcblk1p2 179:2    0 29.6G  0 part /
INFO: copying [/dev/mmcblk1] -> [/dev/mmcblk0]
INFO: [source=/dev/mmcblk1] is a valid block device
ERROR: [destination=/dev/mmcblk0] does not exist
Example: /etc/default/beagle-flasher
source=/dev/mmcblk0
destination=/dev/mmcblk1
rfs_partition=dual
rfs_boot_startmb=1
To save a bunch of different code blocks and formatting, I’ll add a list of the checks I performed via the SSH terminal:
debian@BeagleBone:~$ ls /dev/mmc*
/dev/mmcblk1  /dev/mmcblk1p1  /dev/mmcblk1p2
debian@BeagleBone:~$ lsblk
debian@BeagleBone:~$ dmesg | grep mmc
[    0.000000] Kernel command line: console=ttyS2,115200n8 earlycon=ns16550a,mmio32,0x02800000 root=/dev/mmcblk1p2 ro rootfstype=ext4 rootwait net.ifnames=0
[    2.474251] mmc0: CQHCI version 5.10
[    2.492090] vdd_mmc1: supplied by vsys_3v3
[    2.522070] mmc0: SDHCI controller on 4f80000.mmc [4f80000.mmc] using ADMA 64-bit
[    2.636404] mmc0: mmc_select_hs200 failed, error -110
[    2.641450] mmc0: error -110 whilst initialising MMC card
[    2.780622] mmc0: mmc_select_hs200 failed, error -110
[    2.785666] mmc0: error -110 whilst initialising MMC card
[    2.938007] mmc0: mmc_select_hs200 failed, error -110
[    2.943055] mmc0: error -110 whilst initialising MMC card
[    3.114163] mmc0: mmc_select_hs200 failed, error -110
[    3.119208] mmc0: error -110 whilst initialising MMC card
[    4.637393] mmc1: CQHCI version 5.10
[    5.701240] mmc1: SDHCI controller on 4fb0000.mmc [4fb0000.mmc] using ADMA 64-bit
[    5.769855] mmc1: new ultra high speed DDR50 SDHC card at address aaaa
[    5.777093] mmcblk1: mmc1:aaaa SC32G 29.7 GiB
[    5.787213]  mmcblk1: p1 p2
[    6.740885] EXT4-fs (mmcblk1p2): mounted filesystem with ordered data mode. Opts: (null)
[    8.449473] EXT4-fs (mmcblk1p2): re-mounted. Opts: errors=remount-ro
[   10.341079] FAT-fs (mmcblk1p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
debian@BeagleBone:~$ dmesg | grep -A5 -B5 mmc0
[    2.347866] usb usb2: Product: xHCI Host Controller
[    2.352731] usb usb2: Manufacturer: Linux 5.10.90-ti-arm64-r28 xhci-hcd
[    2.359336] usb usb2: SerialNumber: xhci-hcd.0.auto
[    2.364401] hub 2-0:1.0: USB hub found
[    2.368157] hub 2-0:1.0: 1 port detected
[    2.483067] gpio gpiochip2: gpio-line-names is length 37 but should be at most length 36
[    2.497074] omap-mailbox 31f80000.mailbox: omap mailbox rev 0x66fc7100
[    2.503977] omap-mailbox 31f81000.mailbox: omap mailbox rev 0x66fc7100
[    2.510890] omap-mailbox 31f82000.mailbox: omap mailbox rev 0x66fc7100
[    2.517745] omap-mailbox 31f83000.mailbox: omap mailbox rev 0x66fc7100
[    2.524560] omap-mailbox 31f84000.mailbox: omap mailbox rev 0x66fc7100
[    2.541877] j721e-pcie 2910000.pcie: host bridge /bus@100000/pcie@2910000 ranges:
[    2.549447] j721e-pcie 2910000.pcie:       IO 0x0018001000..0x0018010fff -> 0x0018001000
[    2.557594] j721e-pcie 2910000.pcie:      MEM 0x0018011000..0x001fffffff -> 0x0018011000
[    2.562066] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.565732] j721e-pcie 2910000.pcie:   IB MEM 0x0000000000..0xffffffffffff -> 0x0000000000
[    2.726426] usb 1-1: New USB device found, idVendor=0451, idProduct=8142, bcdDevice= 1.00
[    2.734602] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=1
[    2.741735] usb 1-1: SerialNumber: AF0500891EA6
[    2.746776] hub 1-1:1.0: USB hub found
[    2.750556] hub 1-1:1.0: 4 ports detected
[    2.854080] usb 2-1: new SuperSpeed Gen 1 USB device number 2 using xhci-hcd
[    2.878302] usb 2-1: New USB device found, idVendor=0451, idProduct=8140, bcdDevice= 1.00
[    2.886476] usb 2-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[    2.894039] hub 2-1:1.0: USB hub found
[    2.897849] hub 2-1:1.0: 4 ports detected
[    3.574348] j721e-pcie 2910000.pcie: PCI host bridge to bus 0000:00
[    3.580613] pci_bus 0000:00: root bus resource [bus 00-0f]
[    3.586088] pci_bus 0000:00: root bus resource [io  0x0000-0xffff] (bus address [0x18001000-0x18010fff])
[    3.595548] pci_bus 0000:00: root bus resource [mem 0x18011000-0x1fffffff]
[    3.602434] pci 0000:00:00.0: [104c:b00d] type 01 class 0x060400
debian@BeagleBone:~$ sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 65536 bytes
I/O size (minimum/optimal): 65536 bytes / 65536 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/mmcblk1: 29.72 GiB, 31914983424 bytes, 62333952 sectors
Disklabel type: dos
Disk identifier: 0xd59fd312
Device         Boot  Start      End  Sectors  Size Id Type
/dev/mmcblk1p1 *      2048   264191   262144  128M  c W95 FAT32 (LBA)
/dev/mmcblk1p2      264192 62333951 62069760 29.6G 83 Linux
debian@BeagleBone:~$ cat /proc/device-tree/model
BeagleBoard.org BeagleBone AI-64debian@BeagleBone:~$ sudo i2cdetect -l
i2c-3   i2c             OMAP I2C adapter                        I2C adapter
i2c-1   i2c             OMAP I2C adapter                        I2C adapter
i2c-8   i2c             OMAP I2C adapter                        I2C adapter
i2c-6   i2c             OMAP I2C adapter                        I2C adapter
i2c-4   i2c             OMAP I2C adapter                        I2C adapter
i2c-2   i2c             OMAP I2C adapter                        I2C adapter
i2c-0   i2c             OMAP I2C adapter                        I2C adapter
i2c-9   i2c             OMAP I2C adapter                        I2C adapter
i2c-7   i2c             OMAP I2C adapter                        I2C adapter
i2c-5   i2c             OMAP I2C adapter                        I2C adapter
debian@BeagleBone:~$ sudo dmesg | grep -i hs400
debian@BeagleBone:~$ sudo dmesg | grep -i timeout
debian@BeagleBone:~$ sudo dmesg | grep -i cqhci
debian@BeagleBone:~$ sudo cat /sys/kernel/debug/mmc0/ios
clock:          0 Hz
vdd:            0 (invalid)
bus mode:       2 (push-pull)
chip select:    0 (don't care)
power mode:     0 (off)
bus width:      0 (1 bits)
timing spec:    0 (legacy)
signal voltage: 0 (3.30 V)
driver type:    0 (driver type B)
debian@BeagleBone:~$ sudo dmesg | grep -i mmc0
debian@BeagleBone:~$ sudo dmesg | grep -i regulator
[    1.849625] at24 2-0050: supply vcc not found, using dummy regulator
[    9.541168] ov5640 4-003c: supply DOVDD not found, using dummy regulator
[    9.572935] ov5640 4-003c: supply AVDD not found, using dummy regulator
[    9.596381] ov5640 4-003c: supply DVDD not found, using dummy regulator
[    9.852736] ov5640 8-003c: supply DOVDD not found, using dummy regulator
[    9.876145] ov5640 8-003c: supply AVDD not found, using dummy regulator
[    9.884558] ov5640 8-003c: supply DVDD not found, using dummy regulator
debian@BeagleBone:~$ sudo fdisk -l | grep mmc
debian@BeagleBone:~$ ls -l /dev/disk/by-path
total 0
lrwxrwxrwx 1 root root 13 Jul 13  2021 platform-4fb0000.mmc -> ../../mmcblk1
lrwxrwxrwx 1 root root 15 Jul 13  2021 platform-4fb0000.mmc-part1 -> ../../mmcblk1p1
lrwxrwxrwx 1 root root 15 Jul 13  2021 platform-4fb0000.mmc-part2 -> ../../mmcblk1p2
The key findings I see are:
  • Flasher script attempts to copy to mmc0 but fails
  • Debian does not see mmc0 (eMMC) in list of mmc devices
  • Debian only sees SD card
  • Debian reports mmc0: error -110 whilst initializing MMC card
  • Debian reports mmc0: mmc_select_hs200 failed, attempted and failed high-speed MMC negotiation
  • Debian detects MMC controller mmc0: CQHCI version 5.10
  • Correct BBAI64 device tree loaded
  • Debian powers down eMMC interface
clock: 0 Hz
vdd: 0 (invalid)
power mode: 0 (off)
I have not validated if U Boot can see the MMC as I am waiting on the 3 pin serial cable adaptor to arrive in the mail, however I have low confidence this will resolve my issues.
What am I missing here? Did I potentially receive a defective BBAI64?
yeah this sounds like a corrupt eMMC, how were you powering the board at that time? USB or 5Volt.. The serial cable will help to see what u-boot is stuck on.. The factory image (u-boot) is so old at this point, it has some known problems with newer microSD cards..
Regards
The entire time I have been powering from DC barrel jack 5V 3A supply. I only connect USBC when the board is already powered.
Is this something repairable by myself or do I need to RMA the board?
once you get the cable, we should be able to reflash the eMMC… it’s up to you, it should have booted to an older xfce desktop out of the box. (finding the “active” mDP → HDMI cables can be fun thou..)
Cable should be here tomorrow or the day after. Do you have any links/documentation on what I’ll be doing to reflash the eMMC. I have no issue giving it a go. I got the last unit from the vendor so I’d be buying elsewhere with an additional $40-70 tariff added.
Once you connect the serial port, you will see a u-boot option to reflash the eMMC..
Flash a microSD with the newest image from bb-imager-rs..
On the BBAI64, insert microSD, turn on power.. Hold both RESET and BOOT, let go of RESET, u-boot 2026.10 should load over serial. Select the ‘flashing’ option, usually the last in the u-boot selection list.
@RobertCNelson How robust is the timing on the emmc? On my odroid c2 the board couldn’t cope with the speed of the fast storage, so it had to be down clocked in the device tree so it worked. This could be done in uboot, and that was a good solution, as it worked even when the device tree was updated. I’ll try and find the tread. https://forum.odroid.com/viewtopic.php?p=215724#p215724
