BBB all leds on when connected a microSD
when I insert a microSD Gb all leds but the first are on and can’t do nothing.
Yes, I’m a newbie.
Thank you in advance.
What happens if you don’t insert the SD card? Does it still boot?
Did you try going to http://circuitco.com/support/BeagleBoneBlack? That is the link on the white card that came in the box.
Did you check under the FAQ section for .2.8 How can I use a uSD in the uSD slot as extra storage on my BeagleBone Black??
Without the microSD it boots normaly.
Could it be because it’s a 8 GB and the new hight speed UHS-1.
My intention is to install debian in the BBB.
I didn’t find nothing about the meaning of the leds on.
Thank you for your help.
You must add a uenv.txt file as indicated in the link I sent to th eSD card.
Sorry Gerald, but just to be sure it is clear. Case matters so “uEnv.txt” . . . Hate to be nickpicking, but in this case it does matter :confused:
Sure. Not an issue. All they have to do is read the link I sent and my typing skills would not matter.
nod fair enough.
I did go to the link and make sure it was right after your comment!
Thank for your help, I didn’t follow the document :frowning:
Now is booting!
Next step install debian!
regards
It always pays to follow the document! Glad you got it working.
Always need to read the “destructions” :slight_smile:
