BBB and sonar sensor
I am new to BBB and I want to use HC-SR04 Sonar sensor, because it is cheap. I googled for that solution and I found out, that it has some problem to integrate this sensor with BBB. the video and blogpost are almost 2 years old, so I want to ask you if anything has changed and if there exists some cheap and easy solution? Different sensor perhaps?
