BBB: Battery Cape and Breadboard Cape
I don’t see the breadboard cape in the compatibility matrix. Does that mean it’s compatible with everything? I imagine that it would be on the SW side, but to be sure, is it stackable with any other cape? This is most relevant for me with the battery cape.
The breadboard cape works great! I’ve been using it for projects, such as this one: http://circuitco.com/support/index.php?title=8x8_Bi-Color_LED_Matrix
Thanks Juan. Do you know if it’s compatible with the battery cape?
Also, did you consider using this cape from Adafruit: http://www.adafruit.com/products/572
Bread board is compatible with everything. It doesn’t have anything on it. No EEPROM. It has an LED and buttons, but they are not wired to anything. You put them wherever you want.
