Hi Venkat,
Thanks for the tips.
For (1) I hand edited my log statements when I posted to change the tense of the sentence…no issue here except a lesson for me not to do that
For (2) I tried using pinMode too and this is what I get:
var b = require(‘bonescript’);
// Setup:
function printStatus(x) {
console.log('value = ’ + x.value);
console.log('err = ’ + x.err);
console.log(x);
function printPinMux(x) {
console.log(x.pin + ': mux = ’ + x.mux + ', pullup = ’ + x.pullup + ‘, slew = ’ + x.slew + ‘, options = ’ + x.options.join(’,’) + ', err = ’ + x.err);
// Set pins to HIGH outputs (to turn relays off since they are active low):
var numPins = 40;
var starting_pin = 3;
var connector = “P8”;
var skip = 1; // every second pin
var state = b.HIGH;
pins = new Array(numPins);
console.log(“Initializing pins to GPIO and setting to HIGH”);
for (var i = 0; i < numPins; i++) {
name = connector + “_” + (i*skip + starting_pin);
pins[i] = name;
b.pinMode(name, b.OUTPUT, 7, ‘pullup’, ‘fast’);
b.getPinMode(name, printPinMux);
b.digitalWrite(name, state);
// Loop:
function loop() {
var state = b.HIGH;
return function () {
if (state == b.HIGH) state = b.LOW;
else state = b.HIGH;
console.log("Setting pins “+pins+” to " + state);
name = pins[i];
// Start loop:
setInterval(loop(), 1000);
And the output is:
P8_3: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad6,mmc1_dat6,NA,NA,NA,NA,NA,gpio1_6, err = undefined
P8_4: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad7,mmc1_dat7,NA,NA,NA,NA,NA,gpio1_7, err = undefined
P8_5: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad2,mmc1_dat2,NA,NA,NA,NA,NA,gpio1_2, err = undefined
P8_6: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad3,mmc1_dat3,NA,NA,NA,NA,NA,gpio1_3, err = undefined
P8_7: mux = 7, pullup = pullup, slew = fast, options = gpmc_advn_ale,NA,NA,NA,NA,NA,NA,mmc1_sdcd, err = undefined
P8_8: mux = 7, pullup = pullup, slew = fast, options = gpmc_oen_ren,NA,NA,NA,NA,NA,NA,gpio2_3, err = undefined
P8_9: mux = 7, pullup = pullup, slew = fast, options = gpmc_ben0_cle,NA,NA,NA,NA,NA,NA,gpio2_5, err = undefined
P8_10: mux = 7, pullup = pullup, slew = fast, options = gpmc_wen,NA,NA,NA,NA,NA,NA,gpio2_4, err = undefined
P8_11: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad13,lcd_data18,mmc1_dat5,mmc2_dat1,eqep2B_in,pr1_mii0_txd,pr1_pru0_pru_r30_15,gpio1_13, err = undefined
P8_12: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad12,lcd_data19,mmc1_dat4,mmc2_dat0,eqep2a_in,pr1_mii0_txd2,pr1_pru0_pru_r30_14,gpio1_12, err = undefined
P8_13: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad9,lcd_data22,mmc1_dat1,mmc2_dat5,ehrpwm2B,pr1_mii0_col,NA,gpio0_23, err = undefined
P8_14: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad10,lcd_data21,mmc1_dat2,mmc2_dat6,ehrpwm2_tripzone_input,pr1_mii0_txen,NA,gpio0_26, err = undefined
P8_16: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad14,lcd_data17,mmc1_dat6,mmc2_dat2,eqep2_index,pr1_mii0_txd0,pr1_pru0_pru_r31_14,gpio1_14, err = undefined
P8_15: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad15,lcd_data16,mmc1_dat7,mmc2_dat3,eqep2_strobe,pr1_ecap0_ecap_capin_apwm_o,pr1_pru0_pru_r31_15,gpio1_15, err = undefined
P8_17: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad11,lcd_data20,mmc1_dat3,mmc2_dat7,ehrpwm0_synco,pr1_mii0_txd3,NA,gpio0_27, err = undefined
P8_18: mux = 7, pullup = pulldown, slew = fast, options = gpmc_clk,lcd_memory_clk_mux,NA,mmc2_clk,NA,NA,mcasp0_fsr,gpio2_1, err = undefined
P8_20: mux = 2, pullup = pullup, slew = fast, options = gpmc_csn2,gpmc_be1n,mmc1_cmd,pr1_edio_data_in7,pr1_edio_data_out7,pr1_pru1_pru_r30_13,pr1_pru1_pru_r31_13,gpio1_31, err = undefined
P8_19: mux = 7, pullup = pulldown, slew = fast, options = gpmc_ad8,lcd_data23,mmc1_dat0,mmc2_dat4,ehrpwm2A,pr1_mii_mt0_clk,NA,gpio0_22, err = undefined
P8_21: mux = 2, pullup = pullup, slew = fast, options = gpmc_csn1,gpmc_clk,mmc1_clk,pr1_edio_data_in6,pr1_edio_data_out6,pr1_pru1_pru_r30_12,pr1_pru1_pru_r31_12,gpio1_30, err = undefined
P8_22: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad5,mmc1_dat5,NA,NA,NA,NA,NA,gpio1_5, err = undefined
P8_23: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad4,mmc1_dat4,NA,NA,NA,NA,NA,gpio1_4, err = undefined
P8_24: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad1,mmc1_dat1,NA,NA,NA,NA,NA,gpio1_1, err = undefined
P8_25: mux = 1, pullup = pullup, slew = fast, options = gpmc_ad0,mmc1_dat0,NA,NA,NA,NA,NA,gpio1_0, err = undefined
P8_26: mux = 7, pullup = pullup, slew = fast, options = gpmc_csn0,NA,NA,NA,NA,NA,NA,gpio1_29, err = undefined
P8_27: mux = 0, pullup = pulldown, slew = fast, options = lcd_vsync,gpmc_a8,NA,pr1_edio_data_in2,pr1_edio_data_out2,pr1_pru1_pru_r30_8,pr1_pru1_pru_r31_8,gpio2_22, err = undefined
P8_28: mux = 0, pullup = pulldown, slew = fast, options = lcd_pclk,gpmc_a10,pr1_mii0_crs,pr1_edio_data_in4,pr1_edio_data_out4,pr1_pru1_pru_r30_10,pr1_pru1_pru_r31_10,gpio2_24, err = undefined
P8_29: mux = 0, pullup = pulldown, slew = fast, options = lcd_hsync,gpmc_a9,NA,pr1_edio_data_in3,pr1_edio_data_out3,pr1_pru1_pru_r30_9,pr1_pru1_pru_r31_9,gpio2_23, err = undefined
P8_30: mux = 0, pullup = pulldown, slew = fast, options = lcd_ac_bias_en,gpmc_a11,pr1_mii1_crs,pr1_edio_data_in5,pr1_edio_data_out5,pr1_pru1_pru_r30_11,pr1_pru1_pru_r31_11,gpio2_25, err = undefined
P8_31: mux = 0, pullup = disabled, slew = fast, options = lcd_data14,gpmc_a18,NA,mcasp0_axr1,NA,NA,NA,gpio0_10, err = undefined
P8_32: mux = 0, pullup = disabled, slew = fast, options = lcd_data15,gpmc_a19,NA,mcasp0_ahclkx,mcasp0_axr3,NA,NA,gpio0_11, err = undefined
P8_33: mux = 0, pullup = disabled, slew = fast, options = lcd_data13,gpmc_a17,NA,mcasp0_fsr,mcasp0_axr3,NA,NA,gpio0_9, err = undefined
P8_34: mux = 0, pullup = disabled, slew = fast, options = lcd_data11,gpmc_a15,NA,mcasp0_ahclkr,mcasp0_axr2,NA,NA,gpio2_17, err = undefined
P8_35: mux = 0, pullup = disabled, slew = fast, options = lcd_data12,gpmc_a16,NA,mcasp0_aclkr,mcasp0_axr2,NA,NA,gpio0_8, err = undefined
P8_36: mux = 0, pullup = disabled, slew = fast, options = lcd_data10,gpmc_a14,ehrpwm1A,mcasp0_axr0,mcasp0_axr0,pr1_mii0_rxd1,uart3_ctsn,gpio2_16, err = undefined
P8_37: mux = 0, pullup = disabled, slew = fast, options = lcd_data8,gpmc_a12,NA,mcasp0_aclkx,NA,NA,uart2_ctsn,gpio2_14, err = undefined
P8_38: mux = 0, pullup = disabled, slew = fast, options = lcd_data9,gpmc_a13,NA,mcasp0_fsx,NA,NA,uart2_rtsn,gpio2_15, err = undefined
P8_39: mux = 0, pullup = disabled, slew = fast, options = lcd_data6,gpmc_a6,pr1_edio_data_in6,eqep2_index,pr1_edio_data_out6,pr1_pru1_pru_r30_6,pr1_pru1_pru_r31_6,gpio2_12, err = undefined
P8_40: mux = 0, pullup = disabled, slew = fast, options = lcd_data7,gpmc_a7,pr1_edio_data_in7,eqep2_strobe,pr1_pru1_pru_r30_7,pr1_pru_pru1_r30_7,pr1_pru1_pru_r31_7,gpio2_13, err = undefined
P8_41: mux = 0, pullup = disabled, slew = fast, options = lcd_data4,gpmc_a4,pr1_mii0_txd1,eQEP2A_in,NA,pr1_pru1_pru_r30_4,pr1_pru1_pru_r31_4,gpio2_10, err = undefined
P8_42: mux = 0, pullup = disabled, slew = fast, options = lcd_data5,gpmc_a5,pr1_mii0_txd0,eqep2b_in,NA,pr1_pru1_pru_r30_5,pr1_pru1_pru_r31_5,gpio2_11, err = undefined
Setting pins P8_3,P8_4,P8_5,P8_6,P8_7,P8_8,P8_9,P8_10,P8_11,P8_12,P8_13,P8_14,P8_15,P8_16,P8_17,P8_18,P8_19,P8_20,P8_21,P8_22,P8_23,P8_24,P8_25,P8_26,P8_27,P8_28,P8_29,P8_30,P8_31,P8_32,P8_33,P8_34,P8_35,P8_36,P8_37,P8_38,P8_39,P8_40,P8_41,P8_42 to 0
Setting pins P8_3,P8_4,P8_5,P8_6,P8_7,P8_8,P8_9,P8_10,P8_11,P8_12,P8_13,P8_14,P8_15,P8_16,P8_17,P8_18,P8_19,P8_20,P8_21,P8_22,P8_23,P8_24,P8_25,P8_26,P8_27,P8_28,P8_29,P8_30,P8_31,P8_32,P8_33,P8_34,P8_35,P8_36,P8_37,P8_38,P8_39,P8_40,P8_41,P8_42 to 1
Hooking up an LED to blink the output, only the pins with mux=7 are behaving as outputs. The ‘pullup’ setter doesn’t seem to do anything but the reported value seems accurate.
I’m on kernel 3.8.11.
Glen
