I have a problem with connection to BBB. My friend gave me the board that was used before. Probably it has some software installed in the memory.
When for the first time I connected the BBB to USB the LED_Power diode flash for 1 s and the disappear, other LEDs are dark.
I tried to install the latest software on my sd card and flash with the latest software. First I install the software on my sd card, second, I put the sd card in the slot, third I pushed the BOOT button and then connect the USB, but after that, the LED_power diode flash only for 1 s and nothing happened. I read that i need to change the command line like here: “To turn these images into eMMC flasher images, edit the /boot/uEnv.txt file on the Linux partition on the microSD card and remove the ‘#’ on the line with ‘cmdline=init=/opt/scripts/tools/eMMC/init-eMMC-flasher-v3.sh’. Enabling this will cause booting the microSD card to flash the eMMC. Images are no longer provided here for this to avoid people accidentally overwriting their eMMC flash.”. But I can’t see the SD card when I plug it after installation of software to SD slot card in my notebook.
But later I installed this software: Debian 7.5 (BeagleBone Black - 2GB eMMC) 2014-05-14 for eMMC flashing. This time I can see the software image when I plug the sd card to notebook after the installation. But when I put the SD card to BBB and do the same sequence it happening the same. I see the only LED_power flash for 1s and nothing more.
Please help me with that situation.
