BBB Debian 4DCape-43T Touch and Mouse confused
I'm configuring a BBB with Debian
Linux beaglebone 3.8.13-bone67 #1 SMP Wed Sep 24 21:30:03 UTC 2014 armv7l GNU/Linux
It detects I have the 4DCape-43T installed and loads the firmware:
[ 0.662242] bone-capemgr bone_capemgr.9: slot #3: '4D 4.3 LCD CAPE- 4DCAPE-43T ,00A1,4D SYSTEMS ,BB-BONE-LCD4-01'
It then detect my USB mouse
[ 0.673338] mousedev: PS/2 mouse device common for all mice
It assigns the touch device to event1
[ 0.677616] input: ti-tsc as /devices/ocp.3/44e0d000.tscadc/tsc/input/input1
later, it assigns the USB mouse to the same event
[ 1.569478] hid-generic 0003:04F2:0112.0002: input,hidraw1: USB HID v1.10 Mouse [CHICONY USB Keyboard] on usb-musb-hdrc.1.auto-1.1/input1
TSLIB can't detect the touch screen.
If I force it to use input1, it seems works properly.
I can run ts_calibrate and it gets values when I touch the screen.
I have Qt 5.3.2 Fingerpaint application running LinuxFb. If I tell it to use touch as /usr/input/event1, it fails.
If I tell it to use mouse as /usr/input/event1, I can touch the screen and get touch events that move the mouse cursor and do not match the touch points (calibration is way off)
It looks like touch events are coming in through /dev/input/event1, but it identifies itself as a mouse.
Is there some sort of driver or configuration I need to set to make it load the LCD cape correctly?
