Hi Robert,
I built a set of images using the latest image-builder (from the master branch), after booting from the SD card, the image fails to flash. There doesn’t appear to be a log file, but after running the beaglebone-black-eMMC-flasher.sh script with -x, it seems that it’s failing in the partition_drive() step. I think it’s because /boot/uboot is mounted in /etc/fstab to the SD card (mmcblk0p1) and the script is trying to umount mmcblk1p1 which isn’t actually mounted, which in turn causes write_failure() to get called. Anyway, here’s the output (below).
-W.
root@beaglebone:/etc/init.d# /bin/bash -x /opt/scripts/tools/beaglebone-black-eMMC-flasher.sh
- grep -q root
- id
- unset boot_drive
++ grep /boot/uboot
++ LC_ALL=C
++ lsblk -l
++ awk ‘{print $1}’ - boot_drive=mmcblk0p1
- ‘[’ xmmcblk0p1 = x ‘]’
- ‘[’ xmmcblk0p1 = xmmcblk0p1 ‘]’
- source=/dev/mmcblk0
- destination=/dev/mmcblk1
- ‘[’ xmmcblk0p1 = xmmcblk1p1 ‘]’
- check_running_system
- ‘[’ ‘!’ -f /boot/uboot/uEnv.txt ‘]’
- echo -----------------------------
