Hi everybody,
I have a problem with a successive reboot of the BBB.
I put a watchdog script which verifies continuously if the application under the BBB runs well. After a number of fails, the watchdog forces the reboot of the BBB.
However, the BBB does not reboot after a random number of successive reboots. So, we need to boot it manualy (disconnect and reconnect Ethernet cable because the BBB is powered by POE).
Anybody knows if there is a security mechanism which prevents the restart of the BBB? or if the fail of the reboot is caused by something else.
- The power led is activated.
- in /var/log.syslog, last message :
Jan 23 15:07:40 [XXX] shutdown[3642]: shutting down for system reboot
Jan 23 15:07:40 [XXX] init: Switching to runlevel: 6
Jan 23 15:07:40 [XXX] init: /etc/inittab[74]: duplicate ID field “T0”
Jan 23 15:07:42 [XXX] avahi-daemon[2121]: Got SIGTERM, quitting.
Jan 23 15:07:42 [XXX] avahi-daemon[2121]: Leaving mDNS multicast group on interface eth0.IPv6 with address fe80::caa0:30ff:feac:53e1.
Jan 23 15:07:42 [XXX] avahi-daemon[2121]: Leaving mDNS multicast group on interface eth0.IPv4 with address 192.168.42.203.
Jan 23 15:07:42 [XXX] avahi-daemon[2121]: avahi-daemon 0.6.31 exiting.
Jan 23 15:07:44 [XXX] kernel: [ 311.441231] musb-hdrc musb-hdrc.1.auto: shutdown urb de6010c0 ep2in-bulk
Jan 23 15:07:44 [XXX]: [ 311.441277] musb-hdrc musb-hdrc.1.auto: shutdown urb de349640 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441308] musb-hdrc musb-hdrc.1.auto: shutdown urb de601cc0 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441338] musb-hdrc musb-hdrc.1.auto: shutdown urb de601d40 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441367] musb-hdrc musb-hdrc.1.auto: shutdown urb de349140 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441397] musb-hdrc musb-hdrc.1.auto: shutdown urb de9ab3c0 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441427] musb-hdrc musb-hdrc.1.auto: shutdown urb de601340 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441457] musb-hdrc musb-hdrc.1.auto: shutdown urb de601140 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441486] musb-hdrc musb-hdrc.1.auto: shutdown urb de601ec0 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441516] musb-hdrc musb-hdrc.1.auto: shutdown urb de9ab840 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441545] musb-hdrc musb-hdrc.1.auto: shutdown urb de9ab7c0 ep2in-bulk
Jan 23 15:07:44 [XXX] kernel: [ 311.441575] musb-hdrc musb-hdrc.1.auto: shutdown urb de601e40 ep2in-bulk
Jan 23 15:07:47 [XXX] logger: Stopped at Fri Jan 23 15:07:46 CET 2015.
Jan 23 15:07:47 [XXX] mysqld: 150123 15:07:47 [Note] /usr/sbin/mysqld: Normal shutdown
Jan 23 15:07:47 [XXX] mysqld: 150123 15:07:47 [Note] Event Scheduler: Purging the queue. 0 events
Jan 23 15:07:47 [XXX] mysqld: 150123 15:07:47 InnoDB: Starting shutdown…
Jan 23 15:07:48 [XXX] mysqld: 150123 15:07:48 InnoDB: Shutdown completed; log sequence number 50498649
Jan 23 15:07:48 [XXX] mysqld: 150123 15:07:48 [Note] /usr/sbin/mysqld: Shutdown complete
Jan 23 15:07:48 [XXX] mysqld_safe: mysqld from pid file /var/run/mysqld/mysqld.pid ended
Jan 23 15:07:50 [XXX] acpid: exiting
- nothing in dmesg
