BBB does not recognize usb3 seagate 5TB drive
I’m wanting to use a BBB as a backup server for a cloud-based mysqld. I’m running ubuntu 13.10 and I got a Seagate 5TB usb3 ntfs expansion drive. I’m using it with my desktop that runs centos and everything’s OK. But when I tried moving the drive to the BBB, it simply does not recognize it, i.e. “ls /dev” shows no difference before and after I plug it in. I’m so used to things like this just working that I’m really not sure where to start.
Not enough information given.
Just a suggestion.
Could it be because it is USB-3 ?
The BBB uses USB2 ….
Can you try a USB2 drive or possibly a smaller capacity drive ???
Anyone else ?
“No one could make a greater mistake than he who did nothing because he could do only a little.”
“All that is necessary for the triumph of evil is that good men do nothing” Edmond Burke (1729 - 1797)
http://www.packtpub.com/building-a-home-security-system-with-beaglebone/book
http://ca.linkedin.com/pub/bill-pretty/2b/b07/602
After you insert your drive, what errors do you see when you run the command dmesg?
John
I bet his driver only use usb power supply from BBB board
Thanks for the pointer. The drive was spinning up OK; a bit of not reading well on my part. The problem was that I hadn’t installed ntfs-3g. I had read in the docs that ntfs was installed in ubuntu by default so I hadn’t installed it. Turns out they are not the same thing. One note, when I installed ntfs-3g there were many error messages, several of which said that they were fatal. However, I was able to mount the drive anyway and it seems to work.
