I’ve been experimenting with the BBB 32k eeprom. During this time I’ve fudged the eeprom up pretty good and got the system to a point where it doesn’t boot. I get:
Using: dtb=am335x-boneblack.dtb …
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
** Invalid partition 3 **
** Invalid partition 4 **
** Invalid partition 5 **
** Invalid partition 6 **
** Invalid partition 7 **
Error: “bootcmd_nand0” not defined
This same thing happened with “dtb”, where it suddenly became “undefined”. I placed a definition in the uEnv and that fixed it… but later, “bootcmd_nand0” became an issue. Anyone know how to define bootcmd_nand0? Or better yet, how can I restore the eeprom back to factory setting? Was it the eeprom that caused this issue in the first place? Since I was doing nothing else other than writing to eeprom, I wonder if that is what caused the issue. Are u-boot environment variables stored in eeprom? Did I muck them up? Note that booting from an SD card still generates this msg which leads me to believe it’s not flash, it’s e2.
Bryan
