Gerald and Eskimobob,
Thanks for the update. When I initially ordered the board it was listed as compatible. I should probably check the documentation more frequently with how rapidly things change. I will wait for Juan to complete the workaround wiki. In the mean time I have set up the BBB as an SDR receiver using the RTL drivers and a DVB-T stick. A quick antenna build when I get home and I should have functional reception of the passing NOAA weather satellites.
I love the versatility of this little fella!
Juan,
I look forward to reading it. Until the wiki is complete, would you mind forwarding the workaround instructions?
Paul
