Hey
I tried the workaround and the BBB still did not boot. Worser even after removing the cape it did not respond to connect requests with PuTTY althoughI could see the heartbeat pattern LED Flashing. Has the workaround worked for anyone?
Hey
The last time I tried it it worked.
What image were you using when you tried this?
I tried the one mentioned in your blog as well as the latest one in the beagleboard website. Both did not work.
