The screen seems to work, but when I start the X Org X server, nothing show :
/var/log/Xorg.0.log
X.Org X Server 1.12.4
Release Date: 2012-08-27
[ 2334.734] X Protocol Version 11, Revision 0
[ 2334.735] Build Operating System: Linux 3.2.0-4-mx5 armv7l Debian
[ 2334.736] Current Operating System: Linux beaglebone 3.8.13-bone70 #1 SMP PREEMPT Mon Jan 26 12:48:42 CET 2015 armv7l
[ 2334.738] Kernel command line: console=ttyO0,115200n8 capemgr.disable_partno=BB-BONE-EMMC-2G,BB-BONELT-HDMIN video=HDMI-A-1:1024x600MR@60 root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait fixrtc quiet init=/lib/systemd/systemd
[ 2334.742] Build Date: 17 December 2013 08:51:06PM
[ 2334.743] xorg-server 2:1.12.4-6+deb7u2 (Julien Cristau <jcristau@debian.org>)
[ 2334.744] Current version of pixman: 0.26.0
[ 2334.745] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[ 2334.746] Markers: (–) probed, () from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[ 2334.753] (==) Log file: “/var/log/Xorg.0.log”, Time: Mon Feb 24 22:17:40 2014
[ 2334.758] (==) Using config file: “/etc/X11/xorg.conf”
[ 2334.760] (==) Using system config directory “/usr/share/X11/xorg.conf.d”
[ 2334.765] (==) ServerLayout “Builtin Default Layout”
[ 2334.765] () |–>Screen “Builtin Default fbdev Screen 0” (0)
[ 2334.765] () | |–>Monitor “Builtin Default Monitor”
[ 2334.768] () | |–>Device “Builtin Default fbdev Device 0”
[ 2334.769] () Option “BlankTime” “0”
[ 2334.769] () Option “StandbyTime” “0”
[ 2334.770] (**) Option “SuspendTime” “0”
[ 2334.770] (==) Automatically adding devices
[ 2334.770] (==) Automatically enabling devices
[ 2334.771] (WW) The directory “/usr/share/fonts/X11/cyrillic” does not exist.
[ 2334.771] Entry deleted from font path.
[ 2334.771] (WW) The directory “/usr/share/fonts/X11/100dpi/” does not exist.
[ 2334.772] (WW) The directory “/usr/share/fonts/X11/75dpi/” does not exist.
[ 2334.772] Entry deleted from font path.
[ 2334.772] (WW) The directory “/usr/share/fonts/X11/Type1” does not exist.
[ 2334.772] (WW) The directory “/usr/share/fonts/X11/100dpi” does not exist.
[ 2334.772] (WW) The directory “/usr/share/fonts/X11/75dpi” does not exist.
[ 2334.773] Entry deleted from font path.
[ 2334.773] (WW) The directory “/var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType” does not exist.
[ 2334.773] (==) FontPath set to:
/usr/share/fonts/X11/misc,
built-ins
[ 2334.773] (==) ModulePath set to “/usr/lib/xorg/modules”
[ 2334.773] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[ 2334.774] (II) Loader magic: 0xb6f19cf0
[ 2334.774] (II) Module ABI versions:
[ 2334.774] X.Org ANSI C Emulation: 0.4
[ 2334.774] X.Org Video Driver: 12.1
[ 2334.774] X.Org XInput driver : 16.0
[ 2334.774] X.Org Server Extension : 6.0
[ 2334.775] (II) LoadModule: “extmod”
[ 2334.779] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[ 2334.785] (II) Module extmod: vendor=“X.Org Foundation”
[ 2334.785] compiled for 1.12.4, module version = 1.0.0
[ 2334.785] Module class: X.Org Server Extension
[ 2334.786] ABI class: X.Org Server Extension, version 6.0
[ 2334.786] (II) Loading extension SELinux
[ 2334.786] (II) Loading extension MIT-SCREEN-SAVER
[ 2334.786] (II) Loading extension XFree86-VidModeExtension
[ 2334.786] (II) Loading extension XFree86-DGA
[ 2334.786] (II) Loading extension DPMS
[ 2334.787] (II) Loading extension XVideo
[ 2334.787] (II) Loading extension XVideo-MotionCompensation
[ 2334.787] (II) Loading extension X-Resource
[ 2334.787] (II) LoadModule: “dbe”
[ 2334.790] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[ 2334.792] (II) Module dbe: vendor=“X.Org Foundation”
[ 2334.792] compiled for 1.12.4, module version = 1.0.0
[ 2334.792] Module class: X.Org Server Extension
[ 2334.792] ABI class: X.Org Server Extension, version 6.0
[ 2334.793] (II) Loading extension DOUBLE-BUFFER
[ 2334.793] (II) LoadModule: “glx”
[ 2334.795] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 2334.797] (II) Module glx: vendor=“X.Org Foundation”
[ 2334.798] compiled for 1.12.4, module version = 1.0.0
[ 2334.798] ABI class: X.Org Server Extension, version 6.0
[ 2334.798] (==) AIGLX enabled
[ 2334.799] (II) Loading extension GLX
[ 2334.799] (II) LoadModule: “record”
[ 2334.801] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[ 2334.803] (II) Module record: vendor=“X.Org Foundation”
[ 2334.803] compiled for 1.12.4, module version = 1.13.0
[ 2334.804] Module class: X.Org Server Extension
[ 2334.804] ABI class: X.Org Server Extension, version 6.0
[ 2334.804] (II) Loading extension RECORD
[ 2334.804] (II) LoadModule: “dri”
[ 2334.807] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[ 2334.810] (II) Module dri: vendor=“X.Org Foundation”
[ 2334.810] compiled for 1.12.4, module version = 1.0.0
[ 2334.810] ABI class: X.Org Server Extension, version 6.0
[ 2334.811] (II) Loading extension XFree86-DRI
[ 2334.811] (II) LoadModule: “dri2”
[ 2334.813] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[ 2334.815] (II) Module dri2: vendor=“X.Org Foundation”
[ 2334.815] compiled for 1.12.4, module version = 1.2.0
[ 2334.815] ABI class: X.Org Server Extension, version 6.0
[ 2334.816] (II) Loading extension DRI2
[ 2334.816] (II) LoadModule: “modesetting”
[ 2334.818] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 2334.819] (II) Module modesetting: vendor=“X.Org Foundation”
[ 2334.820] compiled for 1.12.4, module version = 0.8.1
[ 2334.820] Module class: X.Org Video Driver
[ 2334.820] ABI class: X.Org Video Driver, version 12.1
[ 2334.820] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 2334.821] (–) using VT number 2
[ 2334.846] (WW) Falling back to old probe method for modesetting
[ 2334.847] (II) modesetting(0): using default device
[ 2334.848] (WW) VGA arbiter: cannot open kernel arbiter, no multi-card support
[ 2334.849] (II) modesetting(0): Creating default Display subsection in Screen section
“Builtin Default fbdev Screen 0” for depth/fbbpp 16/16
[ 2334.849] () modesetting(0): Depth 16, (–) framebuffer bpp 16
[ 2334.850] () modesetting(0): Option “SWcursor” “true”
[ 2334.850] (==) modesetting(0): RGB weight 565
[ 2334.850] (==) modesetting(0): Default visual is TrueColor
[ 2334.850] (II) modesetting(0): ShadowFB: preferred NO, enabled NO
[ 2334.874] (II) modesetting(0): Output HDMI-0 using monitor section Builtin Default Monitor
[ 2334.897] (II) modesetting(0): EDID for output HDMI-0
[ 2334.898] (II) modesetting(0): Manufacturer: DEN Model: 188 Serial#: 1
[ 2334.898] (II) modesetting(0): Year: 2013 Week: 1
[ 2334.898] (II) modesetting(0): EDID Version: 1.3
[ 2334.898] (II) modesetting(0): Digital Display Input
[ 2334.898] (II) modesetting(0): Max Image Size [cm]: horiz.: 15 vert.: 9
[ 2334.899] (II) modesetting(0): Gamma: 2.20
[ 2334.899] (II) modesetting(0): DPMS capabilities: StandBy Suspend Off
[ 2334.899] (II) modesetting(0): Supported color encodings: RGB 4:4:4 YCrCb 4:4:4
[ 2334.899] (II) modesetting(0): First detailed timing is preferred mode
[ 2334.899] (II) modesetting(0): redX: 0.633 redY: 0.340 greenX: 0.320 greenY: 0.622
[ 2334.900] (II) modesetting(0): blueX: 0.155 blueY: 0.042 whiteX: 0.313 whiteY: 0.329
[ 2334.900] (II) modesetting(0): Manufacturer’s mask: 0
[ 2334.900] (II) modesetting(0): Supported detailed timing:
[ 2334.900] (II) modesetting(0): clock: 44.0 MHz Image Size: 153 x 268 mm
[ 2334.901] (II) modesetting(0): h_active: 1024 h_sync: 1072 h_sync_end 1104 h_blank_end 1184 h_border: 0
[ 2334.901] (II) modesetting(0): v_active: 600 v_sync: 603 v_sync_end 613 v_blanking: 619 v_border: 0
[ 2334.901] (II) modesetting(0): Serial No: YDGTD22M0T6B
[ 2334.901] (II) modesetting(0): Monitor name: DELL E2211H
[ 2334.901] (II) modesetting(0): Ranges: V min: 56 V max: 76 Hz, H min: 30 H max: 83 kHz, PixClock max 175 MHz
[ 2334.902] (II) modesetting(0): EDID (in hex):
[ 2334.902] (II) modesetting(0): 00ffffffffffff0010ae880101000000
[ 2334.902] (II) modesetting(0): 01170103800f0978ea01f5a257529f27
[ 2334.902] (II) modesetting(0): 0a505400000001010101010101010101
[ 2334.902] (II) modesetting(0): 0101010101012e1100a0405813203020
[ 2334.903] (II) modesetting(0): 3a00990c0100001e000000ff00594447
[ 2334.903] (II) modesetting(0): 544432324d305436420a000000fc0044
[ 2334.903] (II) modesetting(0): 454c4c204532323131480a20000000fd
[ 2334.903] (II) modesetting(0): 00384c1e5311000a2020202020200032
[ 2334.903] (II) modesetting(0): EDID vendor “DEN”, prod id 392
[ 2334.904] (II) modesetting(0): Using EDID range info for horizontal sync
[ 2334.904] (II) modesetting(0): Using EDID range info for vertical refresh
[ 2334.904] (II) modesetting(0): Printing DDC gathered Modelines:
[ 2334.904] (II) modesetting(0): Modeline "1024x600"x0.0 43.98 1024 1072 1104 1184 600 603 613 619 +hsync +vsync (37.1 kHz eP)
[ 2334.905] (II) modesetting(0): Printing probed modes for output HDMI-0
[ 2334.905] (II) modesetting(0): Modeline "1024x600"x60.0 43.98 1024 1072 1104 1184 600 603 613 619 +hsync +vsync (37.1 kHz eP)
[ 2334.905] (II) modesetting(0): Output HDMI-0 connected
[ 2334.905] (II) modesetting(0): Using exact sizes for initial modes
[ 2334.906] (II) modesetting(0): Output HDMI-0 using initial mode 1024x600
[ 2334.906] (II) modesetting(0): Using default gamma of (1.0, 1.0, 1.0) unless otherwise stated.
[ 2334.906] () modesetting(0): Display dimensions: (150, 90) mm
[ 2334.906] () modesetting(0): DPI set to (173, 169)
[ 2334.906] (II) Loading sub module “fb”
[ 2334.907] (II) LoadModule: “fb”
[ 2334.908] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 2334.910] (II) Module fb: vendor=“X.Org Foundation”
[ 2334.910] compiled for 1.12.4, module version = 1.0.0
[ 2334.910] ABI class: X.Org ANSI C Emulation, version 0.4
[ 2334.917] (==) modesetting(0): Backing store disabled
[ 2334.918] (==) modesetting(0): Silken mouse enabled
[ 2334.918] (II) modesetting(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 2334.920] () modesetting(0): DPMS enabled
[ 2334.920] (WW) modesetting(0): Option “StandbyTime” is not used
[ 2334.920] (WW) modesetting(0): Option “SuspendTime” is not used
[ 2334.920] (WW) modesetting(0): Option “BlankTime” is not used
[ 2335.027] (–) RandR disabled
[ 2335.027] (II) Initializing built-in extension Generic Event Extension
[ 2335.028] (II) Initializing built-in extension SHAPE
[ 2335.028] (II) Initializing built-in extension MIT-SHM
[ 2335.028] (II) Initializing built-in extension XInputExtension
[ 2335.028] (II) Initializing built-in extension XTEST
[ 2335.028] (II) Initializing built-in extension BIG-REQUESTS
[ 2335.028] (II) Initializing built-in extension SYNC
[ 2335.028] (II) Initializing built-in extension XKEYBOARD
[ 2335.029] (II) Initializing built-in extension XC-MISC
[ 2335.029] (II) Initializing built-in extension SECURITY
[ 2335.029] (II) Initializing built-in extension XINERAMA
[ 2335.029] (II) Initializing built-in extension XFIXES
[ 2335.029] (II) Initializing built-in extension RENDER
[ 2335.029] (II) Initializing built-in extension RANDR
[ 2335.030] (II) Initializing built-in extension COMPOSITE
[ 2335.030] (II) Initializing built-in extension DAMAGE
[ 2335.030] (II) SELinux: Disabled on system
[ 2335.261] (II) AIGLX: Screen 0 is not DRI2 capable
[ 2335.262] (II) AIGLX: Screen 0 is not DRI capable
[ 2335.309] (II) AIGLX: Loaded and initialized swrast
[ 2335.310] (II) GLX: Initialized DRISWRAST GL provider for screen 0
[ 2335.319] (II) modesetting(0): Damage tracking initialized
[ 2335.319] (II) modesetting(0): Setting screen physical size to 270 x 158
[ 2335.530] (II) config/udev: Adding input device tps65217_pwr_but (/dev/input/event0)
[ 2335.531] () tps65217_pwr_but: Applying InputClass “evdev keyboard catchall”
[ 2335.531] (II) LoadModule: “evdev”
[ 2335.532] (II) Loading /usr/lib/xorg/modules/input/evdev_drv.so
[ 2335.532] (II) Module evdev: vendor=“X.Org Foundation”
[ 2335.532] compiled for 1.12.1, module version = 2.7.0
[ 2335.532] Module class: X.Org XInput Driver
[ 2335.532] ABI class: X.Org XInput driver, version 16.0
[ 2335.533] (II) Using input driver ‘evdev’ for ‘tps65217_pwr_but’
[ 2335.533] () tps65217_pwr_but: always reports core events
[ 2335.533] () evdev: tps65217_pwr_but: Device: “/dev/input/event0”
[ 2335.533] (–) evdev: tps65217_pwr_but: Vendor 0 Product 0
[ 2335.533] (–) evdev: tps65217_pwr_but: Found keys
[ 2335.533] (II) evdev: tps65217_pwr_but: Configuring as keyboard
[ 2335.533] () Option “config_info” “udev:/sys/devices/ocp.3/44e0b000.i2c/i2c-0/0-0024/input/input0/event0”
[ 2335.534] (II) XINPUT: Adding extended input device “tps65217_pwr_but” (type: KEYBOARD, id 6)
[ 2335.534] () Option “xkb_rules” “evdev”
[ 2335.534] () Option “xkb_model” “pc105”
[ 2335.534] () Option “xkb_layout” “us”
[ 2335.538] (II) config/udev: Adding input device FocalTech Lab FTxxxx MultiTouch (/dev/input/event1)
[ 2335.538] () FocalTech Lab FTxxxx MultiTouch: Applying InputClass “evdev touchscreen catchall”
[ 2335.538] (II) Using input driver ‘evdev’ for ‘FocalTech Lab FTxxxx MultiTouch’
[ 2335.538] () FocalTech Lab FTxxxx MultiTouch: always reports core events
[ 2335.538] () evdev: FocalTech Lab FTxxxx MultiTouch: Device: “/dev/input/event1”
[ 2335.539] (–) evdev: FocalTech Lab FTxxxx MultiTouch: Vendor 0x10c4 Product 0x81b9
[ 2335.539] (–) evdev: FocalTech Lab FTxxxx MultiTouch: Found absolute axes
[ 2335.539] (–) evdev: FocalTech Lab FTxxxx MultiTouch: Found x and y absolute axes
[ 2335.539] (–) evdev: FocalTech Lab FTxxxx MultiTouch: Found absolute touchscreen
[ 2335.539] (II) evdev: FocalTech Lab FTxxxx MultiTouch: Configuring as touchscreen
[ 2335.539] () evdev: FocalTech Lab FTxxxx MultiTouch: YAxisMapping: buttons 4 and 5
[ 2335.539] () evdev: FocalTech Lab FTxxxx MultiTouch: EmulateWheelButton: 4, EmulateWheelInertia: 10, EmulateWheelTimeout: 200
[ 2335.539] () Option “config_info” “udev:/sys/devices/ocp.3/47400000.usb/musb-hdrc.1.auto/usb1/1-1/1-1:1.0/input/input1/event1”
[ 2335.540] (II) XINPUT: Adding extended input device “FocalTech Lab FTxxxx MultiTouch” (type: TOUCHSCREEN, id 7)
[ 2335.540] (II) evdev: FocalTech Lab FTxxxx MultiTouch: initialized for absolute axes.
[ 2335.541] () FocalTech Lab FTxxxx MultiTouch: (accel) keeping acceleration scheme 1
[ 2335.541] () FocalTech Lab FTxxxx MultiTouch: (accel) acceleration profile 0
[ 2335.541] () FocalTech Lab FTxxxx MultiTouch: (accel) acceleration factor: 2.000
[ 2335.541] () FocalTech Lab FTxxxx MultiTouch: (accel) acceleration threshold: 4
[ 2335.542] (II) config/udev: Adding input device FocalTech Lab FTxxxx MultiTouch (/dev/input/mouse0)
[ 2335.543] (II) No input driver specified, ignoring this device.
[ 2335.543] (II) This device may have been added with another device file.
I’m trying to understand what does it mean all that …
