BBB, how to install chipsee 7inch screen and gfx driver with lastet debian image?
hi!
i have a BBB and chipsee screen, i need a debian so with opengl es support, can anybody help me with this?
thaks for share!
i have some problem to install gfx driver in prebuild image (3.18.13 kernel)
Grab the latest image:
http://elinux.org/Beagleboard:BeagleBoneBlack_Debian#Debian_Image_Testing_Snapshots
and set /boot/uEnv.txt
dtb=am335x-boneblack-bbb-exp-c.dtb
dtb=am335x-boneblack-bbb-exp-r.dtb
Depending if you have the resistive or capacitive screen:
and update xorg for 24bit:
sudo sed -i -e 's:16:24:g' /etc/X11/xorg.conf
thanks you robert!
i use this image:
[https://rcn-ee.com/rootfs/bb.org/testing/2016-02-21/lxqt-4gb/bone-debian-8.3-lxqt-4gb-armhf-2016-02-21-4gb.img.xz](https://rcn-ee.com/rootfs/bb.org/testing/2016-02-21/lxqt-4gb/bone-debian-8.3-lxqt-4gb-armhf-2016-02-21-4gb.img.xz)
apt-get update & upgrade
sudo nano /boot/uEnv.txt
(the screen work fine)
cd /opt/scripts/tools/
git pull
sudo ./update_kernel.sh--bone-kernel --lts
sudo reboot
(compiling this in a debian desktop machine following these instructions: [http://elinux.org/BeagleBoardDebian#SGX_BeagleBone.2FBeagleBone_Black](http://elinux.org/BeagleBoardDebian#SGX_BeagleBone.2FBeagleBone_Black))
sudo tar xfv GFX_5.01.01.02.tar.gz -C /
cd /opt/gfxinstall/
sudo ./sgx-install.sh
sudo reboot
uname -a
Linux beaglebone 4.1.18-bone19 #1 Wed Feb 17 00:04:55 UTC 2016 armv7l GNU/Linux
lsmod | grep omaplfb
omaplfb                11966  0
pvrsrvkm              146952  1 omaplfb
tilcdc                 27901  1 omaplfb
but demos do not work
/opt/gfxsdkdemos# ./335x-demo
0x10205
release9.x
./335x-demo: 16: ./335x-demo: devmem2: not found
installing 8.x SGX debug user libraries
./335x-demo: 18: cd: can't cd to /opt/gfxlibraries/gfx_dbg_es8.x
./335x-demo: 19: ./335x-demo: ./install.sh: not found
./335x-demo: 22: ./335x-demo: [[: not found
dont found this folders:
ogles2
ogles
and my program when execute sudo make run output this
[ error ] ofAppGLFWWindow: 65542: X11: Failed to open X display
[ error ] ofAppGLFWWindow: couldn't init GLFW
[ error ] ofAppGLFWWindow: 65537: The GLFW library is not initialized
any idea?
thanks you robert!
i use this image:
git pull
sudo reboot
BeagleBoardDebian - eLinux.org)
cd /opt/gfxinstall/
sudo reboot
uname -a
GNU/Linux
omaplfb 11966 0
0x10205
release9.x
an init script already takes care of loading the modules, so the
"335x-demo" needs to be patched, and devmem2 isn't needed...
ogles2
ogles
X11... First line of:
Note, these are FBDEV only, no xorg/x11/etc...
We've never had x11 support for the am335x, and we NEVER will..
Rebuild qt5 with eglfs, there's a lots of guilds in this forum, that
works for opengl es...
i use this image:
sudo sed -i -e ‘s:16:24:g’ /etc/X11/xorg.conf
git pull
sudo ./update_kernel.sh–bone-kernel --lts
sudo reboot
cd /opt/gfxinstall/
sudo reboot
uname -a
GNU/Linux
omaplfb 11966 0
0x10205
release9.x
./335x-demo: 18: cd: can’t cd to /opt/gfxlibraries/gfx_dbg_es8.x
“335x-demo” needs to be patched, and devmem2 isn’t needed…
ogles2
ogles
[ error ] ofAppGLFWWindow: couldn’t init GLFW
X11… First line of:
Note, these are FBDEV only, no xorg/x11/etc…
We’ve never had x11 support for the am335x, and we NEVER will…
Rebuild qt5 with eglfs, there’s a lots of guilds in this forum, that
works for opengl es…
How does one know if qt was build with eglfs. I thought that mine was but I cannot seem to get xcb working at all. It is just not available as an option when running code.
I dont have x11 support installed. Headless only.
sorry, iam a newbie.
but, why the demo does not work?
I need a working demo to try to change my code and make it work with FBdev
I'm trying to use openframeworks in a BBB
http://openframeworks.cc/
Thanks for your answers!!
Taking advantage of the thread, I would like to make a question in reference to both, Chipsee TFT & BBB.
@Damian, does your system work fine just installed?
I have followed the instructions wrote here (except the SGX ones, by the moment I’m not going further), but the touch panel does not work well even after calibration. It only works in a half-part of the screen.
What kernel are you working with? How did you calibrate the screen? Could you share the calibration file (/etc/pointercal.xinput.EP0790M09), please?
  • Also, does the speaker works for you? This is another issue I have, audio works well through headphones, but the speaker.
I am trying to get Chipsee “Beaglebone Black Expansion (Capacitive) 1024*600 Pixel 7 Inch LCD, 5-Point Capacitive Touch” working with the latest image:
bone-debian-9.5-lxqt-armhf-2018-08-20-4gb.img
(1) uboot loads the special dtb fine:
loading /boot/dtbs/4.14.62-ti-r71/am335x-boneblack-bbb-exp-c.dtb …
57497 bytes read in 138 ms (406.3 KiB/s)
(2) xorg.conf default depth is set to 24.
However, /dev/fb0 is not created. Any idea why?
The hardware is working well with the old CD supplied software.
Please help!
Thanks, Enoch.
