I am Sampath working on a project with Beaglebone black. I am new to this board and facing an issue while sharing the internet with my Beaglebone black via USB. I have wifi connection as my host. I tried sharing this with my BBB but nothing seemed work. I am using windows 8.1 with Putty as SSH connection.
I tried these steps:
I changed the settings of my host network properties to share its network with the BBB.
Then I changed the properties of BBB ethernet to obtain IP address and DNS automatically.
On BBB console, I set 192.168.7.1 as default gateway with the following command.
.* sudo /sbin/route add default gw 192.168.7.2
Then I tried pinging 192.168.7.1 but it did not ping.
Then I tried pinging 8.8.8.8 still did not ping.
Then I tried naming the server:
echo “nameserver 8.8.8.8” >> /etc/resolv.conf
Later I started pinging 8.8.8.8 -does not work.
I am using Beaglebone Black(Rev C) board, with the latest debian image installed.
I have it working following this tutorial and thanks to Graham’s response in this discussion to replace the last step by typing in the terminal “sudo nano /etc/resolv.conf” to add “nameserver 8.8.8.8” to the resolv.conf file.
Note: I tried this on my Pocketbeagle and not on a BBB.
I suggest that you follow exactly the same steps from the beginning.
Thank you for your response. I tried following the steps provided on the tutorial link that you sent. I still have the same problem after editing /etc/resolv.conf file. I do not know what is going wrong here. You can see my output in the below image.
On Thu, 9 Aug 2018 05:10:09 -0700 (PDT), sampath kumar k
<sampump3@gmail.com> declaimed the following:
Hi An Ra,
What does traceroute (Windows tracert) return?
You appear to have nameserver functionality since the ping was able to
obtain an IP# for the name of the host you tried to ping.
I would tend to suspect there are firewall rules, possibly on the
computer on which you are trying to use connection sharing.
