BBB Jessie image with UART4 support
Hello Robert,
I am yet reluctant to build images by myself... Having seen your rapid
jessie updates... will you provide support for UART4 any soon as
curretly it recognizes just /dev/ttyS[0-3] ?
Have to demo an application to a cient on the BBB next week and hate to
go back to 2014 wheezy for issues with Python :frowning:
TIA, Enoch.
I have my serial capes today, so i'm testing, this change:
+CONFIG_SERIAL_8250_NR_UARTS=10
+CONFIG_SERIAL_8250_RUNTIME_UARTS=10
Once i verfiy that, i'll push them out asap..
and pushed out.. should hi the repo's a few hours:
sudo apt-get update ; sudo apt-get install linux-image-3.14.35-ti-r55
; sudo reboot
Otherwise a *.deb will be available here shortly:
http://builds.beagleboard.org/builders/build-kernel/builds/8
Thank you!
By the way, isn't an ./update_kernel.sh supposed to do the same?
Regards, Enoch.
Robert Nelson <robertcnelson@gmail.com>
writes:
it 'should'.... (that script is just a wrapper around apt-get..)
http://builds.beagleboard.org/linux/8.html
but my builds are done..
http://rcn-ee.homeip.net:81/farm/deb/
and rsync is running... So give a it a few minutes.. :wink:
Hi Robert,
Sorry, this created /dev/ttyS4 indeed but it does not seem to work.
I also checked for echo by shorting UART4 RXD P9-11 to TXD P9-13.
                                and UART1 RXD P9-26 to TXD P9-24.
TIA, Regards, Enoch.
writes:
Enoch:
I am confused about your problem.
I am running the March 1 jessie snapshot.
I am using UART4 to talk to a GPS.
In this case, UART4 appears on ttyO4.
It works fine, and Termios is also happy.
You do have to create a custom “.dtb” using Robert Nelson’s dtb-rebuilder to
both enable the driver and remap the pin-mux, so that the UART4 is connected to
the P9-11 and P9-13.
Have you created the necessary “.dtb” ?
— Graham
You need a DTB with the UARTs enabled. See:
https://github.com/RobertCNelson/dtb-rebuilder/tree/3.14-ti
In particular, for ttyO4 you’ll want to look at:
https://github.com/RobertCNelson/dtb-rebuilder/blob/3.14-ti/src/arm/am335x-boneblack-ttyO4.dts
The steps are:
git clone https://github.com/RobertCNelson/dtb-rebuilder.git cd dtb-rebuilder git checkout 3.14-ti make src/arm/am335x-boneblack-ttyO4.dtb cp src/arm/am335x-boneblack-ttyO4.dtb /boot/dtbs/uname -r`/
Then you’ll need to edit /boot/uEnv.txt and add:
dtb=am335x-boneblack-ttyO4.dtb
Then reboot; check dmesg to make sure that the pinmux-helper has properly set up the pins for uart mode.
-W
If all that you want different from the default configuration is ttyO4 working, then Winston’s advice is good.
If there are other/additional changes, then you will need to make additional edits or changes to the “.dts” or “.dti” files.
— Graham
Just need someone to build it. :wink:
The best place is in the 'getting started' which is already powered by nodejs...
