H Guyz,
I followed this link http://wiki.beyondlogic.org/index.php/BeagleBoneBlack_Building_Kernel but my kernel is not booting in BBB,Please help m ein proceedign further…I built the kernel and booted through tftp but my kernel is hung!!!
U-Boot SPL 2013.04-dirty (Jun 19 2013 - 09:57:14)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (Jun 19 2013 - 09:57:14)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
1449 bytes read in 4 ms (353.5 KiB/s)
reading /boot/uImage
** Unable to read file /boot/uImage **
U-Boot#
U-Boot#
U-Boot#
U-Boot#
U-Boot# setenv serverip 192.168.0.1;setenv ipaddr 192.168.0.100;tftp 0x80007fc0 uImage;tftp 0x80f80000 am335x-bone.dtb
link up on port 0, speed 100, full duplex
Using cpsw device
TFTP from server 192.168.0.1; our IP address is 192.168.0.100
Filename ‘uImage’.
Load address: 0x80007fc0
Loading: #################################################################
