I’ve been trying to build a BBB kernel using Robert Nelson’s scripts from the instructions
on eewiki; however, there seems to be no way to download the git sources. Does anyone
have a working script for this?
I’m building on a 32-bit machine, and the Linaro compiler is 64-bit, but if I can just get the
correctly patched sources I should be ok. I’d skip the Linaro stuff, but I can’t work out the
format of the name for a local toolchain.
Running build_kernel.sh I get:
scripts/git: LINUX_GIT not defined in system.sh
cloning kernel/git/torvalds/linux.git - Linux kernel source tree into default location: /home/cwr/BBB/linux-dev/ignore/linux-src
Cloning into ‘/home/cwr/BBB/linux-dev/ignore/linux-src’…
fatal: unable to access ‘kernel/git/torvalds/linux.git - Linux kernel source tree’: SSL certificate problem: unable to get local issuer certificate
Any ideas?
Thanks - Will
