I have a beaglebone black which is under ubuntu 14.04 - kernel 4.1.13-ti-r36 installed following the well known eewiki page from Robert C Nelson.
I’ve use few days my beaglebone and, when I upgrade and reboot today, my computer (ubuntu14.04 also) is always looking for connection to the usb/beaglebone (192.168.7.2).
In order to understand what’s happening, I plug an ftdi usb to the serial port : here is what has been returned…
I don’t understand anything except I could not use my bbb until I re-flash my card. I’ve made an iso few days ago so I can easily used it but I’m curious…
Does anyone know what happens?
U-Boot SPL 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06)
U-Boot 2015.01-00001-gb2412df (Jan 29 2015 - 15:01:06), Build: jenkins-github_Bootloader-Builder-105
Watchdog enabled
I2C: ready
DRAM: 512 MiB
Using default environment
cpsw
Hit any key to stop autoboot: 1 0
switch to partitions #0, OK
mmc0 is current device
Checking for: /uEnv.txt …
Checking for: /boot.scr …
Checking for: /boot/boot.scr …
Checking for: /boot/uEnv.txt …
80 bytes read in 39 ms (2 KiB/s)
Using: dtb=am335x-boneblack-overlay.dtb …
Checking if uname_r is set in /boot/uEnv.txt…
Running uname_boot …
loading /boot/vmlinuz-4.1.13-ti-r36 …
8265056 bytes read in 492 ms (16 MiB/s)
loading /boot/dtbs/4.1.13-ti-r36/am335x-boneblack-overlay.dtb …
56738 bytes read in 75 ms (738.3 KiB/s)
loading /boot/initrd.img-4.1.13-ti-r36 …
4427848 bytes read in 289 ms (14.6 MiB/s)
debug: [console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait fixrtc] …
debug: [bootz 0x82000000 0x88080000:439048 0x88000000] …
Kernel image @ 0x82000000 [ 0x000000 - 0x7e1d60 ]
Loading Ramdisk to 8fbc6000, end 8ffff048 … OK
Loading Device Tree to 8fbb5000, end 8fbc5da1 … OK
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.1.13-ti-r36 (root@b2-omap5-uevm-2gb) (gcc version 4.8.4 (Ubuntu/Linaro 4.8.4-2ubuntu1~14.04) ) #1 SMP PREEMPT Fri Dec 11 04:55:22 UTC 2015
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] Machine model: TI AM335x BeagleBone Black
[ 0.000000] cma: Reserved 24 MiB at 0x9e000000
[ 0.000000] Memory policy: Data cache writeback
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] AM335X ES2.1 (sgx neon )
[ 0.000000] PERCPU: Embedded 13 pages/cpu @df927000 s23104 r8192 d21952 u53248
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129408
[ 0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/mmcblk0p1 ro rootfstype=ext4 rootwait fixrtc
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 470988K/522240K available (10669K kernel code, 936K rwdata, 3712K rodata, 688K init, 901K bss, 26676K reserved, 24576K cma-reserved, 0K highmem)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc0e139b4 (14383 kB)
[ 0.000000] .init : 0xc0e14000 - 0xc0ec0000 ( 688 kB)
[ 0.000000] .data : 0xc0ec0000 - 0xc0faa294 ( 937 kB)
[ 0.000000] .bss : 0xc0fad000 - 0xc108e618 ( 902 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] RCU dyntick-idle grace-period acceleration is enabled.
[ 0.000000] RCU restricting CPUs from NR_CPUS=2 to nr_cpu_ids=1.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[ 0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000037] clocksource timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000050] OMAP clocksource: timer1 at 24000000 Hz
[ 0.000428] Console: colour dummy device 80x30
[ 0.000456] WARNING: Your ‘console=ttyO0’ has been replaced by ‘ttyS0’
[ 0.000465] This ensures that you still see kernel messages. Please
[ 0.000473] update your kernel commandline.
[ 0.000496] Calibrating delay loop… 996.14 BogoMIPS (lpj=4980736)
[ 0.088852] pid_max: default: 32768 minimum: 301
[ 0.089005] Security Framework initialized
[ 0.089090] AppArmor: AppArmor disabled by boot time parameter
[ 0.089102] Yama: becoming mindful.
[ 0.089322] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.089337] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.090271] Initializing cgroup subsys blkio
[ 0.090301] Initializing cgroup subsys memory
[ 0.090351] Initializing cgroup subsys devices
[ 0.090372] Initializing cgroup subsys freezer
[ 0.090402] Initializing cgroup subsys net_cls
[ 0.090420] Initializing cgroup subsys perf_event
[ 0.090439] Initializing cgroup subsys net_prio
[ 0.090500] CPU: Testing write buffer coherency: ok
[ 0.090563] ftrace: allocating 34862 entries in 103 pages
[ 0.184473] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.184613] Setting up static identity map for 0x80008280 - 0x800082d8
[ 0.238863] Brought up 1 CPUs
[ 0.238889] SMP: Total of 1 processors activated (996.14 BogoMIPS).
[ 0.238899] CPU: All CPU(s) started in SVC mode.
[ 0.239852] devtmpfs: initialized
[ 0.258141] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 0.278220] omap_hwmod: tptc0 using broken dt data from edma
[ 0.278450] omap_hwmod: tptc1 using broken dt data from edma
[ 0.278656] omap_hwmod: tptc2 using broken dt data from edma
[ 0.284576] omap_hwmod: debugss: _wait_target_disable failed
[ 0.339409] clocksource jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.341534] xor: measuring software checksum speed
[ 0.438877] arm4regs : 1219.600 MB/sec
[ 0.538808] 8regs : 904.000 MB/sec
[ 0.638807] 32regs : 1018.800 MB/sec
[ 0.738808] neon : 1652.000 MB/sec
[ 0.738818] xor: using function: neon (1652.000 MB/sec)
[ 0.738996] pinctrl core: initialized pinctrl subsystem
[ 0.741100] NET: Registered protocol family 16
[ 0.743974] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.768856] cpuidle: using governor ladder
[ 0.798837] cpuidle: using governor menu
[ 0.803958] OMAP GPIO hardware version 0.1
[ 0.804843] GPIO line 52 (EMMC ResetN) hogged as output/high
[ 0.816830] No ATAGs?
[ 0.816865] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.818922] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.818941] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 1.018898] raid6: int32x1 gen() 207 MB/s
[ 1.188823] raid6: int32x1 xor() 175 MB/s
[ 1.358975] raid6: int32x2 gen() 312 MB/s
[ 1.528886] raid6: int32x2 xor() 205 MB/s
[ 1.698893] raid6: int32x4 gen() 266 MB/s
[ 1.868857] raid6: int32x4 xor() 202 MB/s
[ 2.038907] raid6: int32x8 gen() 291 MB/s
[ 2.208813] raid6: int32x8 xor() 173 MB/s
[ 2.378822] raid6: neonx1 gen() 1458 MB/s
[ 2.548822] raid6: neonx2 gen() 1869 MB/s
[ 2.718809] raid6: neonx4 gen() 1944 MB/s
[ 2.888853] raid6: neonx8 gen() 1153 MB/s
[ 2.888863] raid6: using algorithm neonx4 gen() 1944 MB/s
[ 2.888872] raid6: using intx1 recovery algorithm
[ 2.898643] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 2.902188] vgaarb: loaded
[ 2.902956] SCSI subsystem initialized
[ 2.903745] usbcore: registered new interface driver usbfs
[ 2.903824] usbcore: registered new interface driver hub
[ 2.903937] usbcore: registered new device driver usb
[ 2.904588] omap_i2c 44e0b000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c0_pins, deferring probe
[ 2.904650] omap_i2c 4819c000.i2c: could not find pctldev for node /ocp/l4_wkup@44c00000/scm@210000/pinmux@800/pinmux_i2c2_pins, deferring probe
[ 2.904787] pps_core: LinuxPPS API ver. 1 registered
