BBB not booting
Hi, I’m using several BBB, but one started failing to boot, and now is not booting at all. I used 3 different power supplies, and tried to power it by the usb, but I always get a Kernel panic (reading the debug port). I tried with the already running custom emmc, also with an SD card with a custom image (which works fine in my others BBB) and with an SD card with BBB-eMMC-flasher-2013.06.20.img.
The debug messages for each one are:
booting from emmc:
U-Boot SPL 2013.04-dirty (May 06 2013 - 16:12:47)
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
OMAP SD/MMC: 0
mmc_send_cmd : timeout: No status update
reading u-boot.img
reading u-boot.img
U-Boot 2013.04-dirty (May 06 2013 - 16:12:47)
I2C: ready
DRAM: 512 MiB
WARNING: Caches not enabled
NAND: No NAND device found!!!
0 MiB
Phy not found
PHY reset timed out
cpsw, usb_ether
Hit any key to stop autoboot: 1 0
Card did not respond to voltage select!
mmc0(part 0) is current device
No micro SD card found, setting mmcdev to 1
SD/MMC found on device 1
reading uEnv.txt
62 bytes read in 3 ms (19.5 KiB/s)
4276632 bytes read in 784 ms (5.2 MiB/s)
24129 bytes read in 36 ms (654.3 KiB/s)
Booting from mmc …
Booting kernel from Legacy Image at 80007fc0 …
Image Name: Angstrom/3.8.13/beaglebone
Data Size: 4276568 Bytes = 4.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum … OK
Flattened Device Tree blob at 80f80000
Booting using the fdt blob at 0x80f80000
XIP Kernel Image … OK
OK
Using Device Tree in place at 80f80000, end 80f88e40
Starting kernel …
[ 0.000000] Initializing cgroup subsys cpu
[ 0.000000] Linux version 3.8.13 (koen@rrMBP) (gcc version 4.7.3 20130205 (prerelease) (Linaro GCC 4.7-2013.02-01) ) #1 SMP Tue Jun 25 08:17:15 EDT 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=50c5387d
[ 0.000000] Machine: Generic AM33XX (Flattened Device Tree), model: TI AM335x BeagleBone
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (neon )
[ 0.000000] PERCPU: Embedded 8 pages/cpu @c0af5000 s9408 r8192 d15168 u32768
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 129792
[ 0.000000] Kernel command line: console=ttyO0,115200n8 capemgr.disable_partno=BB-BONELT-HDMI,BB-BONELT-HDMIN root=/dev/mmcblk0p2 ro rootfstype=ext4 rootwait
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] __ex_table already sorted, skipping sort
[ 0.000000] allocated 1048576 bytes of page_cgroup
[ 0.000000] please try ‘cgroup_disable=memory’ option if you don’t want memory cgroups
[ 0.000000] Memory: 511MB = 511MB total
[ 0.000000] Memory: 510552k/510552k available, 13736k reserved, 0K highmem
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff000000 ( 488 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf800000 - 0xbfe00000 ( 6 MB)
[ 0.000000] .text : 0xc0008000 - 0xc05d79ec (5951 kB)
[ 0.000000] .init : 0xc05d8000 - 0xc06194c0 ( 262 kB)
[ 0.000000] .data : 0xc061a000 - 0xc068bce0 ( 456 kB)
[ 0.000000] .bss : 0xc068bce0 - 0xc06e56fc ( 359 kB)
[ 0.000000] Hierarchical RCU implementation.
[ 0.000000] RCU restricting CPUs from NR_CPUS=4 to nr_cpu_ids=1.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER1 at 24000000 Hz
[ 0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[ 0.000000] OMAP clocksource: GPTIMER2 at 24000000 Hz
[ 0.000000] Console: colour dummy device 80x30
[ 0.000357] Calibrating delay loop… 545.07 BogoMIPS (lpj=531968)
[ 0.015420] pid_max: default: 32768 minimum: 301
[ 0.015654] Security Framework initialized
[ 0.015746] Mount-cache hash table entries: 512
[ 0.026008] Initializing cgroup subsys cpuacct
[ 0.026042] Initializing cgroup subsys memory
[ 0.026107] Initializing cgroup subsys blkio
[ 0.026243] CPU: Testing write buffer coherency: ok
[ 0.026782] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.026858] Setting up static identity map for 0x803728a0 - 0x803728ec
[ 0.028257] Brought up 1 CPUs
[ 0.028283] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.029571] devtmpfs: initialized
[ 0.094430] pinctrl core: initialized pinctrl subsystem
[ 0.094649] rstctl core: initialized rstctl subsystem
[ 0.095134] regulator-dummy: no parameters
[ 0.095706] NET: Registered protocol family 16
[ 0.096529] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106423] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.107185] platform 49000000.edma: alias fck already exists
[ 0.107267] platform 49000000.edma: alias fck already exists
[ 0.107297] platform 49000000.edma: alias fck already exists
[ 0.108625] OMAP GPIO hardware version 0.1
[ 0.113286] gpio-rctrl rstctl.3: loaded OK
[ 0.118585] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.120739] cpsw.0: No hwaddr in dt. Using c8:a0:30:b3:32:45 from efuse
[ 0.120771] cpsw.1: No hwaddr in dt. Using c8:a0:30:b3:32:47 from efuse
[ 0.135478] bio: create slab at 0
[ 0.147488] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.147938] vmmcsd_fixed: 3300 mV
[ 0.150812] SCSI subsystem initialized
[ 0.151237] usbcore: registered new interface driver usbfs
[ 0.151349] usbcore: registered new interface driver hub
[ 0.151653] usbcore: registered new device driver usb
[ 0.153710] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.155186] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.156915] DCDC1: at 1500 mV
[ 0.158109] vdd_mpu: 925 <–> 1325 mV at 1100 mV
[ 0.159209] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.160334] LDO1: at 1800 mV
[ 0.161443] LDO2: at 3300 mV
[ 0.163433] LDO3: 1800 mV
[ 0.164601] LDO4: at 3300 mV
[ 0.165600] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.166338] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.167039] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.169372] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.169589] media: Linux media interface: v0.10
[ 0.169761] Linux video capture interface: v2.00
[ 0.170451] Advanced Linux Sound Architecture Driver Initialized.
[ 0.171763] Switching to clocksource gp_timer
[ 0.189912] NET: Registered protocol family 2
[ 0.190907] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.191050] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.191214] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.191309] TCP: reno registered
[ 0.191336] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191453] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191872] NET: Registered protocol family 1
[ 0.192447] RPC: Registered named UNIX socket transport module.
[ 0.192467] RPC: Registered udp transport module.
[ 0.192481] RPC: Registered tcp transport module.
[ 0.192495] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.193651] CPU PMU: probing PMU on CPU 0
[ 0.193681] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.194139] omap2_mbox_probe: platform not supported
[ 0.197982] VFS: Disk quotas dquot_6.5.2
[ 0.198217] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.199451] NFS: Registering the id_resolver key type
[ 0.199599] Key type id_resolver registered
[ 0.199618] Key type id_legacy registered
[ 0.199683] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.200129] msgmni has been set to 997
[ 0.202958] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.202984] io scheduler noop registered
[ 0.203000] io scheduler deadline registered
[ 0.203041] io scheduler cfq registered (default)
[ 0.204751] tps65217-bl tps65217-bl: no platform data provided
[ 0.204794] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.205746] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.208277] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.208571] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 0.904867] console [ttyO0] enabled
[ 0.909555] [drm] Initialized drm 1.1.0 20060810
[ 0.928104] brd: module loaded
[ 0.938375] loop: module loaded
[ 0.941837] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.949130] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.956410] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.963688] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.970978] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.985242] bone-capemgr bone_capemgr.8: Baseboard: ‘A335BNLT,0A5A,1813BBBK6423’
[ 0.993033] bone-capemgr bone_capemgr.8: compatible-baseboard=ti,beaglebone-black
[ 1.001201] bone-capemgr bone_capemgr.8: Skipping disabled cape with part# BB-BONELT-HDMI
[ 1.009859] bone-capemgr bone_capemgr.8: Skipping disabled cape with part# BB-BONELT-HDMIN
[ 1.048837] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 1.085941] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 1.123050] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 1.160159] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 1.166415] bone-capemgr bone_capemgr.8: slot #4: specific override
[ 1.173023] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 4
[ 1.181065] bone-capemgr bone_capemgr.8: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 1.191216] bone-capemgr bone_capemgr.8: slot #5: specific override
[ 1.197818] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 5
[ 1.205859] bone-capemgr bone_capemgr.8: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 1.215926] bone-capemgr bone_capemgr.8: slot #6: specific override
[ 1.222529] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 6
[ 1.230569] bone-capemgr bone_capemgr.8: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[ 1.240921] bone-capemgr bone_capemgr.8: Skipping loading of disabled cape with part# BB-BONELT-HDMI
[ 1.250510] bone-capemgr bone_capemgr.8: Skipping loading of disabled cape with part# BB-BONELT-HDMIN
[ 1.260356] bone-capemgr bone_capemgr.8: initialized OK.
[ 1.265973] bone-capemgr bone_capemgr.8: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.274829] bone-capemgr bone_capemgr.8: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.285559] OneNAND driver initializing
[ 1.291148] usbcore: registered new interface driver asix
[ 1.296963] usbcore: registered new interface driver cdc_ether
[ 1.303127] bone-capemgr bone_capemgr.8: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.312020] usbcore: registered new interface driver smsc95xx
[ 1.318096] bone-capemgr bone_capemgr.8: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[ 1.331762] usbcore: registered new interface driver net1080
[ 1.337797] usbcore: registered new interface driver cdc_subset
[ 1.344041] bone-capemgr bone_capemgr.8: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[ 1.354808] usbcore: registered new interface driver zaurus
[ 1.360823] usbcore: registered new interface driver cdc_ncm
[ 1.367050] bone-capemgr bone_capemgr.8: slot #4: #2 overlays
[ 1.373912] usbcore: registered new interface driver cdc_acm
[ 1.379883] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.388273] Initializing USB Mass Storage driver…
[ 1.394288] bone-capemgr bone_capemgr.8: slot #4: Applied #2 overlays.
[ 1.401186] bone-capemgr bone_capemgr.8: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.410195] usbcore: registered new interface driver usb-storage
[ 1.416526] USB Mass Storage support registered.
[ 1.421606] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.428319] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.433598] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.442613] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.447679] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.453786] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.459038] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.467997] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.473046] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.478359] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.484769] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.493204] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.500340] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.507921] usb usb1: Product: MUSB HDRC host driver
[ 1.513143] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 1.518817] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.525139] hub 1-0:1.0: USB hub found
[ 1.529187] hub 1-0:1.0: 1 port detected
[ 1.534751] mousedev: PS/2 mouse device common for all mice
[ 1.543038] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.550539] 44e3e000.rtc: already running
[ 1.555031] i2c /dev entries driver
[ 1.560341] Driver for 1-wire Dallas network protocol.
[ 1.567222] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.574771] cpuidle: using governor ladder
[ 1.579098] cpuidle: using governor menu
[ 1.583691] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 1.590937] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[ 1.597370] omap_hsmmc mmc.4: unable to select pin group
[ 1.603214] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.610422] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.617772] mmc.4 supply vmmc_aux not found, using dummy regulator
[ 1.624400] omap_hsmmc mmc.4: pins are not configured from the driver
[ 1.658543] gpio-rctrl rstctl.3: gpio_rctrl_request eMMC_RSTn
[ 1.664746] omap_hsmmc mmc.10: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 1.672748] gpio-rctrl rstctl.3: gpio_rctrl_deassert eMMC_RSTn
[ 1.679203] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 1.686356] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 1.693878] mmc.10 supply vmmc_aux not found, using dummy regulator
[ 1.700630] omap_hsmmc mmc.10: pins are not configured from the driver
[ 1.734791] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 1.746475] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 1.753787] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 1.762767] leds-gpio gpio-leds.7: pins are not configured from the driver
[ 1.771166] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.777916] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 1.785163] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.793319] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.799666] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 1.806825] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 1.815060] usbcore: registered new interface driver usbhid
[ 1.820982] usbhid: USB HID core driver
[ 1.828567] TCP: cubic registered
[ 1.832192] Initializing XFRM netlink socket
[ 1.836779] NET: Registered protocol family 17
[ 1.841624] NET: Registered protocol family 15
[ 1.846541] Key type dns_resolver registered
[ 1.851305] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.859441] ThumbEE CPU extension supported.
[ 1.863985] Registering SWP/SWPB emulation handler
[ 1.870014] registered taskstats version 1
[ 1.904635] mmc1: BKOPS_EN bit is not set
[ 1.911637] mmc1: new high speed MMC card at address 0001
[ 1.918159] mmcblk0: mmc1:0001 MMC02G 1.78 GiB
[ 1.923303] mmcblk0boot0: mmc1:0001 MMC02G partition 1 1.00 MiB
[ 1.929565] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.935973] davinci_mdio 4a101000.mdio: no live phy, scanning all
[ 1.942727] mmcblk0boot1: mmc1:0001 MMC02G partition 2 1.00 MiB
[ 1.949451] davinci_mdio: probe of 4a101000.mdio failed with error -5
[ 1.957562] Detected MACID = c8:a0:30:b3:32:45[ 1.962278] mmcblk0: p1 p2
[ 1.965340] Unhandled fault: external abort on non-linefetch (0x1008) at 0xe09d8000
[ 1.973535] Internal error: : 1008 [#1] SMP THUMB2
[ 1.978542] Modules linked in:
[ 1.981746] CPU: 0 Not tainted (3.8.13 #1)
[ 1.986411] PC is at cpsw_probe+0x3fc/0x8a2
[ 1.990793] LR is at ioremap_page_range+0xc3/0x100
[ 1.995804] pc : [] lr : [] psr: 80000133
[ 1.995804] sp : df051e18 ip : df04d760 fp : 00000001
[ 2.007798] r10: df3252a0 r9 : df383d90 r8 : 00000000
[ 2.013260] r7 : e09d8000 r6 : df10d800 r5 : df10d810 r4 : df383800
[ 2.020081] r3 : 00000000 r2 : 00000800 r1 : c023f73d r0 : e09d8000
[ 2.026904] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment kernel
[ 2.034723] Control: 50c5387d Table: 80004019 DAC: 00000015
[ 2.040729] Process swapper/0 (pid: 1, stack limit = 0xdf050240)
[ 2.047006] Stack: (0xdf051e18 to 0xdf052000)
[ 2.051563] 1e00: 00000000 df2a68c0
[ 2.060116] 1e20: c065bc80 df2a68c0 df383a98 c0371233 df04cac0 00000000 df051e4c 00000020
[ 2.068670] 1e40: 00000008 c00ce4c1 df051e90 df382908 df051e78 df04cac0 df382988 df382908
[ 2.077223] 1e60: df382908 c00ce403 00000000 df382908 df10c408 df3429c0 00000000 c00cebdf
[ 2.085775] 1e80: df0464b8 c0040449 00000000 00000003 df10c408 00000000 c06749d0 df10d810
[ 2.094329] 1ea0: df10d844 c06749d0 c01f234d 000000e9 c05eff81 00000000 00000000 c01f2cb9
[ 2.102883] 1ec0: c01f2cad c01f226f 00000000 df10d810 df10d844 c06749d0 c01f234d c01f2381
[ 2.111437] 1ee0: 00000000 df051ef0 c06749d0 c01f139d df046478 df109980 c06749d0 c06749d0
[ 2.119990] 1f00: df3429c0 c066b238 00000000 c01f1d33 c0501397 df001348 c06749d0 c05f8308
[ 2.128543] 1f20: c06165b0 c068bd00 000000e9 c01f2661 00000007 c05f8308 c06165b0 c068bd00
[ 2.137096] 1f40: 000000e9 c000868d c05eff81 13000000 c06165dc 00000008 00000007 c05f8308
[ 2.145650] 1f60: c06165b0 c068bd00 000000e9 c05f8310 c05d81d5 c05d8691 00000007 00000007
[ 2.154201] 1f80: c05d81d5 00000000 00000000 c036aae9 00000000 00000000 00000000 00000000
[ 2.162753] 1fa0: 00000000 c036aaef 00000000 c000c6fd 00000000 00000000 00000000 00000000
[ 2.171304] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.179857] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 f9fee777 f5cbd7e7
[ 2.188438] [] (cpsw_probe+0x3fc/0x8a2) from [] (platform_drv_probe+0xd/0xe)
[ 2.197636] [] (platform_drv_probe+0xd/0xe) from [] (driver_probe_device+0x67/0x144)
[ 2.207555] [] (driver_probe_device+0x67/0x144) from [] (__driver_attach+0x35/0x48)
[ 2.217382] [] (__driver_attach+0x35/0x48) from [] (bus_for_each_dev+0x29/0x48)
[ 2.226845] [] (bus_for_each_dev+0x29/0x48) from [] (bus_add_driver+0x83/0x158)
[ 2.236310] [] (bus_add_driver+0x83/0x158) from [] (driver_register+0x4d/0xa4)
[ 2.245685] [] (driver_register+0x4d/0xa4) from [] (do_one_initcall+0x61/0xec)
[ 2.255072] [] (do_one_initcall+0x61/0xec) from [] (kernel_init_freeable+0xb9/0x14c)
[ 2.265000] [] (kernel_init_freeable+0xb9/0x14c) from [] (kernel_init+0x7/0x90)
[ 2.274471] [] (kernel_init+0x7/0x90) from [] (ret_from_fork+0x11/0x34)
[ 2.283204] Code: ff6c e200 f8c4 05c0 (6803) f44f
[ 2.288216] —[ end trace 0f0f3318cacb70cf ]—
[ 2.295456] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.295456]
booting from custom SD:
OMAP SD/MMC: 0
reading u-boot.img
reading u-boot.img
I2C: ready
DRAM: 512 MiB
0 MiB
Phy not found
PHY reset timed out
cpsw, usb_ether
mmc0 is current device
micro SD card found
SD/MMC found on device 0
reading uEnv.txt
62 bytes read in 4 ms (14.6 KiB/s)
4276632 bytes read in 822 ms (5 MiB/s)
24129 bytes read in 60 ms (392.6 KiB/s)
Booting from mmc …
OK
Starting kernel …
[ 0.000359] Calibrating delay loop… 545.07 BogoMIPS (lpj=531968)
[ 0.015426] pid_max: default: 32768 minimum: 301
[ 0.015658] Security Framework initialized
[ 0.015751] Mount-cache hash table entries: 512
[ 0.025991] Initializing cgroup subsys cpuacct
[ 0.026025] Initializing cgroup subsys memory
[ 0.026090] Initializing cgroup subsys blkio
[ 0.026228] CPU: Testing write buffer coherency: ok
[ 0.026765] CPU0: thread -1, cpu 0, socket -1, mpidr 0
[ 0.026840] Setting up static identity map for 0x803728a0 - 0x803728ec
[ 0.028242] Brought up 1 CPUs
[ 0.028266] SMP: Total of 1 processors activated (545.07 BogoMIPS).
[ 0.029552] devtmpfs: initialized
[ 0.094412] pinctrl core: initialized pinctrl subsystem
[ 0.094628] rstctl core: initialized rstctl subsystem
[ 0.095116] regulator-dummy: no parameters
[ 0.095682] NET: Registered protocol family 16
[ 0.096508] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.106391] pinctrl-single 44e10800.pinmux: 142 pins at pa f9e10800 size 568
[ 0.107155] platform 49000000.edma: alias fck already exists
[ 0.107188] platform 49000000.edma: alias fck already exists
[ 0.107266] platform 49000000.edma: alias fck already exists
[ 0.108597] OMAP GPIO hardware version 0.1
[ 0.113268] gpio-rctrl rstctl.3: loaded OK
[ 0.118569] hw-breakpoint: debug architecture 0x4 unsupported.
[ 0.120719] cpsw.0: No hwaddr in dt. Using c8:a0:30:b3:32:45 from efuse
[ 0.120751] cpsw.1: No hwaddr in dt. Using c8:a0:30:b3:32:47 from efuse
[ 0.135440] bio: create slab at 0
[ 0.147442] edma-dma-engine edma-dma-engine.0: TI EDMA DMA engine driver
[ 0.147893] vmmcsd_fixed: 3300 mV
[ 0.150765] SCSI subsystem initialized
[ 0.151190] usbcore: registered new interface driver usbfs
[ 0.151302] usbcore: registered new interface driver hub
[ 0.151597] usbcore: registered new device driver usb
[ 0.153638] omap_i2c 44e0b000.i2c: bus 0 rev0.11 at 400 kHz
[ 0.155111] input: tps65217_pwr_but as /devices/ocp.2/44e0b000.i2c/i2c-0/0-0024/input/input0
[ 0.157313] DCDC1: at 1500 mV
[ 0.158500] vdd_mpu: 925 <–> 1325 mV at 1100 mV
[ 0.159609] vdd_core: 925 <–> 1150 mV at 1100 mV
[ 0.160784] LDO1: at 1800 mV
[ 0.161946] LDO2: at 3300 mV
[ 0.163922] LDO3: 1800 mV
[ 0.165024] LDO4: at 3300 mV
[ 0.166060] tps65217 0-0024: TPS65217 ID 0xe version 1.2
[ 0.166764] omap_i2c 44e0b000.i2c: unable to select pin group
[ 0.167458] omap_i2c 4819c000.i2c: bus 1 rev0.11 at 100 kHz
[ 0.169885] omap_i2c 4819c000.i2c: unable to select pin group
[ 0.170102] media: Linux media interface: v0.10
[ 0.170202] Linux video capture interface: v2.00
[ 0.170882] Advanced Linux Sound Architecture Driver Initialized.
[ 0.172194] Switching to clocksource gp_timer
[ 0.190417] NET: Registered protocol family 2
[ 0.191406] TCP established hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.191549] TCP bind hash table entries: 4096 (order: 4, 81920 bytes)
[ 0.191712] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.191873] TCP: reno registered
[ 0.191904] UDP hash table entries: 256 (order: 1, 12288 bytes)
[ 0.191951] UDP-Lite hash table entries: 256 (order: 1, 12288 bytes)
[ 0.192372] NET: Registered protocol family 1
[ 0.192950] RPC: Registered named UNIX socket transport module.
[ 0.192970] RPC: Registered udp transport module.
[ 0.192984] RPC: Registered tcp transport module.
[ 0.192998] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.194159] CPU PMU: probing PMU on CPU 0
[ 0.194189] hw perfevents: enabled with ARMv7 Cortex-A8 PMU driver, 5 counters available
[ 0.194643] omap2_mbox_probe: platform not supported
[ 0.198518] VFS: Disk quotas dquot_6.5.2
[ 0.198750] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.199993] NFS: Registering the id_resolver key type
[ 0.200086] Key type id_resolver registered
[ 0.200104] Key type id_legacy registered
[ 0.200170] jffs2: version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
[ 0.200624] msgmni has been set to 997
[ 0.203443] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.203469] io scheduler noop registered
[ 0.203486] io scheduler deadline registered
[ 0.203599] io scheduler cfq registered (default)
[ 0.205244] tps65217-bl tps65217-bl: no platform data provided
[ 0.205287] tps65217-bl: probe of tps65217-bl failed with error -22
[ 0.206254] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[ 0.208783] omap_uart 44e09000.serial: did not get pins for uart0 error: -19
[ 0.209075] 44e09000.serial: ttyO0 at MMIO 0x44e09000 (irq = 88) is a OMAP UART0
[ 0.905484] console [ttyO0] enabled
[ 0.910180] [drm] Initialized drm 1.1.0 20060810
[ 0.928737] brd: module loaded
[ 0.939003] loop: module loaded
[ 0.942466] at24 0-0050: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.949760] at24 1-0054: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.957043] at24 1-0055: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.964324] at24 1-0056: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.971613] at24 1-0057: 32768 byte 24c256 EEPROM, writable, 1 bytes/write
[ 0.985869] bone-capemgr bone_capemgr.8: Baseboard: ‘A335BNLT,0A5A,1813BBBK6423’
[ 0.993661] bone-capemgr bone_capemgr.8: compatible-baseboard=ti,beaglebone-black
[ 1.001828] bone-capemgr bone_capemgr.8: Skipping disabled cape with part# BB-BONELT-HDMI
[ 1.010490] bone-capemgr bone_capemgr.8: Skipping disabled cape with part# BB-BONELT-HDMIN
[ 1.049271] bone-capemgr bone_capemgr.8: slot #0: No cape found
[ 1.086377] bone-capemgr bone_capemgr.8: slot #1: No cape found
[ 1.123487] bone-capemgr bone_capemgr.8: slot #2: No cape found
[ 1.160595] bone-capemgr bone_capemgr.8: slot #3: No cape found
[ 1.166854] bone-capemgr bone_capemgr.8: slot #4: specific override
[ 1.173463] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 4
[ 1.181507] bone-capemgr bone_capemgr.8: slot #4: ‘Bone-LT-eMMC-2G,00A0,Texas Instrument,BB-BONE-EMMC-2G’
[ 1.191659] bone-capemgr bone_capemgr.8: slot #5: specific override
[ 1.198261] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 5
[ 1.206304] bone-capemgr bone_capemgr.8: slot #5: ‘Bone-Black-HDMI,00A0,Texas Instrument,BB-BONELT-HDMI’
[ 1.216372] bone-capemgr bone_capemgr.8: slot #6: specific override
[ 1.222977] bone-capemgr bone_capemgr.8: bone: Using override eeprom data at slot 6
[ 1.231019] bone-capemgr bone_capemgr.8: slot #6: ‘Bone-Black-HDMIN,00A0,Texas Instrument,BB-BONELT-HDMIN’
[ 1.241371] bone-capemgr bone_capemgr.8: Skipping loading of disabled cape with part# BB-BONELT-HDMI
[ 1.250960] bone-capemgr bone_capemgr.8: Skipping loading of disabled cape with part# BB-BONELT-HDMIN
[ 1.260804] bone-capemgr bone_capemgr.8: initialized OK.
[ 1.266422] bone-capemgr bone_capemgr.8: loader: before slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.275280] bone-capemgr bone_capemgr.8: loader: check slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.286019] OneNAND driver initializing
[ 1.291616] usbcore: registered new interface driver asix
[ 1.297416] usbcore: registered new interface driver cdc_ether
[ 1.303583] bone-capemgr bone_capemgr.8: loader: after slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.312476] usbcore: registered new interface driver smsc95xx
[ 1.318556] bone-capemgr bone_capemgr.8: slot #4: Requesting firmware ‘cape-bone-2g-emmc1.dtbo’ for board-name ‘Bone-LT-eMMC-2G’, version ‘00A0’
[ 1.332225] usbcore: registered new interface driver net1080
[ 1.338262] usbcore: registered new interface driver cdc_subset
[ 1.344510] bone-capemgr bone_capemgr.8: slot #4: dtbo ‘cape-bone-2g-emmc1.dtbo’ loaded; converting to live tree
[ 1.355277] usbcore: registered new interface driver zaurus
[ 1.361296] usbcore: registered new interface driver cdc_ncm
[ 1.367529] bone-capemgr bone_capemgr.8: slot #4: #2 overlays
[ 1.374396] usbcore: registered new interface driver cdc_acm
[ 1.380369] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.388761] Initializing USB Mass Storage driver…
[ 1.394778] bone-capemgr bone_capemgr.8: slot #4: Applied #2 overlays.
[ 1.401682] bone-capemgr bone_capemgr.8: loader: done slot-4 BB-BONE-EMMC-2G:00A0 (prio 1)
[ 1.410695] usbcore: registered new interface driver usb-storage
[ 1.417025] USB Mass Storage support registered.
[ 1.422109] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 1.428821] musb-hdrc musb-hdrc.0.auto: pdev->id = 0
[ 1.434086] musb-hdrc musb-hdrc.0.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.443100] musb-hdrc musb-hdrc.0.auto: *** mode=3
[ 1.448166] musb-hdrc musb-hdrc.0.auto: *** power=250
[ 1.454278] musb-hdrc musb-hdrc.1.auto: pdev->id = 1
[ 1.459531] musb-hdrc musb-hdrc.1.auto: drivers/usb/musb/musb_dsps.c:468 dsps_musb_init: OK
[ 1.468496] musb-hdrc musb-hdrc.1.auto: *** mode=1
[ 1.473543] musb-hdrc musb-hdrc.1.auto: *** power=250
[ 1.478856] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.485264] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 1.493702] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.500842] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.508425] usb usb1: Product: MUSB HDRC host driver
[ 1.513647] usb usb1: Manufacturer: Linux 3.8.13 musb-hcd
[ 1.519322] usb usb1: SerialNumber: musb-hdrc.1.auto
[ 1.525646] hub 1-0:1.0: USB hub found
[ 1.529749] hub 1-0:1.0: 1 port detected
[ 1.535283] mousedev: PS/2 mouse device common for all mice
[ 1.543564] omap_rtc 44e3e000.rtc: rtc core: registered 44e3e000.rtc as rtc0
[ 1.551360] i2c /dev entries driver
[ 1.556692] Driver for 1-wire Dallas network protocol.
[ 1.563568] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 1.571119] cpuidle: using governor ladder
[ 1.575446] cpuidle: using governor menu
[ 1.580040] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 1.587281] omap_hsmmc mmc.4: Failed to get rstctl; not using any
[ 1.593713] omap_hsmmc mmc.4: unable to select pin group
[ 1.599555] edma-dma-engine edma-dma-engine.0: allocated channel for 0:25
[ 1.606763] edma-dma-engine edma-dma-engine.0: allocated channel for 0:24
[ 1.614114] mmc.4 supply vmmc_aux not found, using dummy regulator
[ 1.620744] omap_hsmmc mmc.4: pins are not configured from the driver
[ 1.655077] gpio-rctrl rstctl.3: gpio_rctrl_request eMMC_RSTn
[ 1.661285] omap_hsmmc mmc.10: Got rstctl (gpio:#0 name eMMC_RSTn) label:eMMC_RSTn
[ 1.669288] gpio-rctrl rstctl.3: gpio_rctrl_deassert eMMC_RSTn
[ 1.675753] edma-dma-engine edma-dma-engine.0: allocated channel for 0:3
[ 1.682901] edma-dma-engine edma-dma-engine.0: allocated channel for 0:2
[ 1.690426] mmc.10 supply vmmc_aux not found, using dummy regulator
[ 1.697180] omap_hsmmc mmc.10: pins are not configured from the driver
[ 1.731361] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-leds.7
[ 1.743071] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.7) status -22
[ 1.750383] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 1.759362] leds-gpio gpio-leds.7: pins are not configured from the driver
[ 1.767746] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.774581] edma-dma-engine edma-dma-engine.0: allocated channel for 0:36
[ 1.781833] omap-sham 53100000.sham: hw accel on OMAP rev 4.3
[ 1.790278] omap-aes 53500000.aes: OMAP AES hw accel rev: 3.2
[ 1.796647] edma-dma-engine edma-dma-engine.0: allocated channel for 0:5
[ 1.803839] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 1.812437] edma-dma-engine edma-dma-engine.0: allocated channel for 0:6
[ 1.820547] usbcore: registered new interface driver usbhid
[ 1.826491] usbhid: USB HID core driver
[ 1.830617] mmc0: new high speed SDHC card at address 1234
[ 1.839815] TCP: cubic registered
[ 1.843409] Initializing XFRM netlink socket
[ 1.848032] mmcblk0: mmc0:1234 SA04G 3.63 GiB
[ 1.853882] NET: Registered protocol family 17
[ 1.858813] mmcblk0: p1 p2
[ 1.861883] NET: Registered protocol family 15
[ 1.868043] Key type dns_resolver registered
[ 1.872871] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 1.881063] ThumbEE CPU extension supported.
[ 1.885622] Registering SWP/SWPB emulation handler
[ 1.891664] registered taskstats version 1
[ 1.947718] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6
[ 1.954135] davinci_mdio 4a101000.mdio: no live phy, scanning all
[ 1.960995] davinci_mdio: probe of 4a101000.mdio failed with error -5
[ 1.968060] Detected MACID = c8:a0:30:b3:32:45
[ 1.972694] Unhandled fault: external abort on non-linefetch (0x1008) at 0xe09d8000
[ 1.980891] Internal error: : 1008 [#1] SMP THUMB2
[ 1.985897] Modules linked in:
[ 1.989102] CPU: 0 Not tainted (3.8.13 #1)
[ 1.993765] PC is at cpsw_probe+0x3fc/0x8a2
[ 1.998146] LR is at ioremap_page_range+0xc3/0x100
[ 2.003158] pc : [] lr : [] psr: 80000133
[ 2.003158] sp : df051e18 ip : df04d760 fp : 00000001
[ 2.015151] r10: df39ef60 r9 : df33e590 r8 : 00000000
[ 2.020612] r7 : e09d8000 r6 : df10d800 r5 : df10d810 r4 : df33e000
[ 2.027432] r3 : 00000000 r2 : 00000800 r1 : c023f73d r0 : e09d8000
[ 2.034255] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment kernel
[ 2.042074] Control: 50c5387d Table: 80004019 DAC: 00000015
[ 2.048078] Process swapper/0 (pid: 1, stack limit = 0xdf050240)
[ 2.054353] Stack: (0xdf051e18 to 0xdf052000)
[ 2.058910] 1e00: 00000000 00000010
[ 2.067464] 1e20: 002200d0 df2a68c0 df33e298 c0371233 df04cac0 00000000 df051e4c 00000020
[ 2.076017] 1e40: 00000008 c00ce4c1 df051e90 df347248 df051e78 df04cac0 df3472c8 df347248
[ 2.084568] 1e60: df347248 c00ce403 00000000 df347248 df10c408 df3455c0 00000000 c00cebdf
[ 2.093120] 1e80: df0464b8 c0040449 00000000 00000003 df10c408 00000000 c06749d0 df10d810
[ 2.101673] 1ea0: df10d844 c06749d0 c01f234d 000000e9 c05eff81 00000000 00000000 c01f2cb9
[ 2.110227] 1ec0: c01f2cad c01f226f 00000000 df10d810 df10d844 c06749d0 c01f234d c01f2381
[ 2.118782] 1ee0: 00000000 df051ef0 c06749d0 c01f139d df046478 df109980 c06749d0 c06749d0
[ 2.127337] 1f00: df3455c0 c066b238 00000000 c01f1d33 c0501397 df001348 c06749d0 c05f8308
[ 2.135891] 1f20: c06165b0 c068bd00 000000e9 c01f2661 00000007 c05f8308 c06165b0 c068bd00
[ 2.144445] 1f40: 000000e9 c000868d c05eff81 13000000 c06165dc 00000008 00000007 c05f8308
[ 2.152997] 1f60: c06165b0 c068bd00 000000e9 c05f8310 c05d81d5 c05d8691 00000007 00000007
[ 2.161548] 1f80: c05d81d5 00000000 00000000 c036aae9 00000000 00000000 00000000 00000000
[ 2.170100] 1fa0: 00000000 c036aaef 00000000 c000c6fd 00000000 00000000 00000000 00000000
[ 2.178650] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 2.187199] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 d9fee777 f5dfdfe7
[ 2.195778] [] (cpsw_probe+0x3fc/0x8a2) from [] (platform_drv_probe+0xd/0xe)
[ 2.204974] [] (platform_drv_probe+0xd/0xe) from [] (driver_probe_device+0x67/0x144)
[ 2.214893] [] (driver_probe_device+0x67/0x144) from [] (__driver_attach+0x35/0x48)
[ 2.224720] [] (__driver_attach+0x35/0x48) from [] (bus_for_each_dev+0x29/0x48)
[ 2.234183] [] (bus_for_each_dev+0x29/0x48) from [] (bus_add_driver+0x83/0x158)
[ 2.243646] [] (bus_add_driver+0x83/0x158) from [] (driver_register+0x4d/0xa4)
[ 2.253021] [] (driver_register+0x4d/0xa4) from [] (do_one_initcall+0x61/0xec)
[ 2.262407] [] (do_one_initcall+0x61/0xec) from [] (kernel_init_freeable+0xb9/0x14c)
[ 2.272334] [] (kernel_init_freeable+0xb9/0x14c) from [] (kernel_init+0x7/0x90)
[ 2.281806] [] (kernel_init+0x7/0x90) from [] (ret_from_fork+0x11/0x34)
[ 2.290540] Code: ff6c e200 f8c4 05c0 (6803) f44f
[ 2.295553] —[ end trace 8fd089dfdbaf1bb4 ]—
[ 2.300646] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 2.300646]
booting with BBB-eMMC-flasher-2013.06.20.img.:
Phy not found
PHY reset timed out
cpsw, usb_ether
micro SD card found
reading uEnv.txt
14 bytes read in 4 ms (2.9 KiB/s)
4270840 bytes read in 842 ms (4.8 MiB/s)
24125 bytes read in 83 ms (283.2 KiB/s)
Booting from mmc …
Data Size: 4270776 Bytes = 4.1 MiB
OK
Using Device Tree in place at 80f80000, end 80f88e3c
Starting kernel …
[ 0.194362] omap2_mbox_probe: platform not supported
[ 0.204953] tps65217-bl tps65217-bl: no platform data provided
[ 0.281452] bone-capemgr bone_capemgr.9: slot #0: No cape found
[ 0.318561] bone-capemgr bone_capemgr.9: slot #1: No cape found
[ 0.355669] bone-capemgr bone_capemgr.9: slot #2: No cape found
[ 0.392778] bone-capemgr bone_capemgr.9: slot #3: No cape found
[ 0.414525] bone-capemgr bone_capemgr.9: slot #6: BB-BONELT-HDMIN conflict P8.45 (#5:BB-BONELT-HDMI)
[ 0.424130] bone-capemgr bone_capemgr.9: slot #6: Failed verification
[ 0.430906] bone-capemgr bone_capemgr.9: loader: failed to load slot-6 BB-BONELT-HDMIN:00A0 (prio 2)
[ 0.451500] omap_hsmmc mmc.4: of_parse_phandle_with_args of ‘reset’ failed
[ 0.516340] pinctrl-single 44e10800.pinmux: pin 44e10854 already requested by 44e10800.pinmux; cannot claim for gpio-
leds.8
[ 0.528055] pinctrl-single 44e10800.pinmux: pin-21 (gpio-leds.8) status -22
[ 0.535371] pinctrl-single 44e10800.pinmux: could not request pin 21 on device pinctrl-single
[ 0.760819] Unhandled fault: external abort on non-linefetch (0x1008) at 0xe09fe000
[ 0.768836] Internal error: : 1008 [#1] SMP THUMB2
[ 0.773842] Modules linked in:
[ 0.777048] CPU: 0 Not tainted (3.8.13 #1)
[ 0.781711] PC is at cpsw_probe+0x3fc/0x8a2
[ 0.786094] LR is at ioremap_page_range+0xc3/0x100
[ 0.791105] pc : [] lr : [] psr: 80000133
[ 0.791105] sp : df051e18 ip : df04d7f8 fp : 00000001
[ 0.803100] r10: df35b1a0 r9 : df5fbd90 r8 : 00000000
[ 0.808561] r7 : e09fe000 r6 : df10d600 r5 : df10d610 r4 : df5fb800
[ 0.815382] r3 : 00000000 r2 : 00000800 r1 : c023f73d r0 : e09fe000
[ 0.822205] Flags: Nzcv IRQs on FIQs on Mode SVC_32 ISA Thumb Segment kernel
[ 0.830024] Control: 50c5387d Table: 80004019 DAC: 00000015
[ 0.836029] Process swapper/0 (pid: 1, stack limit = 0xdf050240)
[ 0.842305] Stack: (0xdf051e18 to 0xdf052000)
[ 0.846861] 1e00: 00000000 80000000
[ 0.855414] 1e20: 000080d0 df0149c0 df5fba98 c036f873 df04cac0 00000000 df051e4c 00000020
[ 0.863969] 1e40: 00000008 c00ce4c1 df051e90 df5fce08 df051e78 df04cac0 df5fce88 df5fce08
[ 0.872522] 1e60: df5fce08 c00ce403 00000000 df5fce08 df10c148 df3e0740 00000000 c00cebdf
[ 0.881074] 1e80: df0464b8 c0040449 00000000 00000003 df10c148 00000000 c0672990 df10d610
[ 0.889628] 1ea0: df10d644 c0672990 c01f234d 000000e8 c05edf81 00000000 00000000 c01f2cb9
[ 0.898181] 1ec0: c01f2cad c01f226f 00000000 df10d610 df10d644 c0672990 c01f234d c01f2381
[ 0.906735] 1ee0: 00000000 df051ef0 c0672990 c01f139d df046478 df109880 c0672990 c0672990
[ 0.915291] 1f00: df3e0740 c06691f8 00000000 c01f1d33 c04ff0a7 df001348 c0672990 c05f62f0
[ 0.923845] 1f20: c061458c c0689cc0 000000e8 c01f2661 00000007 c05f62f0 c061458c c0689cc0
[ 0.932397] 1f40: 000000e8 c000868d c05edf81 13000000 c06145b8 00000008 00000007 c05f62f0
[ 0.940949] 1f60: c061458c c0689cc0 000000e8 c05f62f8 c05d61d5 c05d6691 00000007 00000007
[ 0.949500] 1f80: c05d61d5 00000000 00000000 c0369129 00000000 00000000 00000000 00000000
[ 0.958052] 1fa0: 00000000 c036912f 00000000 c000c6fd 00000000 00000000 00000000 00000000
[ 0.966602] 1fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 0.975153] 1fe0: 00000000 00000000 00000000 00000000 00000013 00000000 fdeee777 f5cbdfe7
[ 0.983733] [] (cpsw_probe+0x3fc/0x8a2) from [] (platform_drv_probe+0xd/0xe)
[ 0.992931] [] (platform_drv_probe+0xd/0xe) from [] (driver_probe_device+0x67/0x144)
[ 1.002850] [] (driver_probe_device+0x67/0x144) from [] (__driver_attach+0x35/0x48)
[ 1.012677] [] (__driver_attach+0x35/0x48) from [] (bus_for_each_dev+0x29/0x48)
[ 1.022140] [] (bus_for_each_dev+0x29/0x48) from [] (bus_add_driver+0x83/0x158)
[ 1.031605] [] (bus_add_driver+0x83/0x158) from [] (driver_register+0x4d/0xa4)
[ 1.040979] [] (driver_register+0x4d/0xa4) from [] (do_one_initcall+0x61/0xec)
[ 1.050362] [] (do_one_initcall+0x61/0xec) from [] (kernel_init_freeable+0xb9/0x14c)
[ 1.060286] [] (kernel_init_freeable+0xb9/0x14c) from [] (kernel_init+0x7/0x90)
[ 1.069756] [] (kernel_init+0x7/0x90) from [] (ret_from_fork+0x11/0x34)
[ 1.078489] Code: ff6c e200 f8c4 05c0 (6803) f44f
[ 1.083501] —[ end trace 973272b19305d354 ]—
[ 1.088807] Kernel panic - not syncing: Attempted to kill init! exitcode=0x0000000b
[ 1.088807]
[ 1.098361] drm_kms_helper: panic occurred, switching back to text console
Suggestions?
My U-Boot shows the same messages as your third scenario, except “leds.7” instead of “leds.8”. I see lots of people with those “leds” issues, and they don’t seem to be fatal. The real error is a bit later in time, too:
Loren again. Have learned a bunch since this morning. Looks like the earlier parts of the error dump were a distraction. The real error is here:
